  • Falco Friend
    #156981
    I have a problem on “upload to S3” function, after the upload of many files, the progress bar result stopped and the upload blocked. Retrying the upload the problem rsult the same, the file and the progress percentage is different every time i have try.
    Which is the problem ?
    thanks
    Emiliano
    baparks Friend
    #365173
    I’m now having the same problem.
    My details are that I switched providers after completing a site and after switching providers I created a new bucket, set the parameters and tried to start the upload. It goes to 16% and then stops.
    Clearing out the bucket and starting over does the same thing.
    I have the plug in turned off as I don’t have all the files on s3 and turning it on renders the site unusable.
    To get back into the site I had to rename the plugin php, access the back end, turn off the plug in and re rename the plugin php.
    I thought about uninstalling the component and reinstalling it but I see no benefit in the uninstall.
    It doesn’t clear out the database does it? And the stopping can’t be related to a database error can it?
    Could this be a server time out?
    What’s REALLY weird is that Akeeba backs up to it’s bucket with out a problem. (separate bucket)
    sandman1979 Friend
    #365639
    Bit the same idsuue, it stops at around 1500 of 10000 files.
    Can we do a partial upload?
    Thanh Nguyen Viet Friend
    #365720
    <em>@Falco 206412 wrote:</em><blockquote>I have a problem on “upload to S3” function, after the upload of many files, the progress bar result stopped and the upload blocked. Retrying the upload the problem rsult the same, the file and the progress percentage is different every time i have try.
    thanks
    Emiliano</blockquote>
    Hello Falco,
    It maybe have an error when uploading (network, connect to s3 server, …), so upload progress was interrupted.
    the file and the progress percentage is different from each time because some files was uploaded from last upload.
    Best regards,
    ThanhNV
    #365721
    <em>@sandman1979 207136 wrote:</em><blockquote>Bit the same idsuue, it stops at around 1500 of 10000 files.
    Can we do a partial upload?</blockquote>
    Yes, you can select a sub folder to partial upload.
    Please wait a new version 2.0.0, it will be released on this week.
    You will have more options for upload on new version.
    Best regards,
    ThanhNV
    baparks Friend
    #365736
    I’m still having my issue and it’s on the same server in a sub domain/directoryas a few other of my site who do not have this issue
    #365869
    <em>@baparks 207248 wrote:</em><blockquote>I’m still having my issue and it’s on the same server in a sub domain/directoryas a few other of my site who do not have this issue</blockquote>
    You dont need clean up your bucket if upload process is failure.
    Just upload it again, and chose an option “upload without replace existing files”. So, It will only upload the files that has not uploaded before.
    FYI: We will release new version of this component on this week, It have more options for upload. Please wait to try it.
    Best regards,
    ThanhNV
    sandman1979 Friend
    #366015
    ok,
    mine is working now :), doing uploads partially 🙂
    Anyway i have another question, is it possible to let the users avatars from an agora forum also be uploaded to the amazon cloud? with a cronjob so they are working instantly?
    #366059
    <em>@sandman1979 207600 wrote:</em><blockquote>ok,
    Anyway i have another question, is it possible to let the users avatars from an agora forum also be uploaded to the amazon cloud? with a cronjob so they are working instantly?</blockquote>
    Yes, you can upload static files of any joomla extensions to the amazon s3 server, include component agora (please read our document for more information).
    With conjob, the files will be automatically upload according time you set on profile.
    Best regards,
    ThanhNV
This topic contains 9 replies, has 4 voices, and was last updated by  Thanh Nguyen Viet 14 years ago.
