  • themandril2002 Friend
    #129144
    If you see the attached screen shot you will see that our fireboard forum is appearing too wide in the dravity template – I can’t find a place to limit width in the fireboard css file that doesn’t mess it all up. Here’s the site:
    http://www.theajzone.com/members
    but you will have to sign in as:
    user – sample
    pass – sampletest
    and go to the forum
    thank you for your help!
    1. Picture-1
    Menalto Friend
    #254069
    I think this has been solved?
    #254551
    Have u fixed it ?
    taiwi Friend
    #260296
    i have the same Problem with the Fedora Template i can not find why the message View of Fireboard breaks out!!
    Any hint…
    Ralf
    Sie attachment Pic. same as the main thread..
    1. screenshot
    mj1256 Friend
    #260307
    there is a width setting in the parameters of fireboard. make it a smaller number
    #260333
    and it’s fine. I prefer the new look, but it broke out of the template.
    taiwi Friend
    #260514
    Yes same by me the new template just break out and i change the tables width already but no effect, really strange. So i also need to change back i think..
    So bad..
    br.
    Ralf
    taiwi Friend
    #260724
    I find the solution maybe somebody is intrested:
    look to the forum.css file at the default_ex template. Search for
    div.msgtext {
    overflow:auto;
    border-top:1px solid #ddd;
    padding-top:10px;
    margin-top:5px;
    and change it to
    div.msgtext {
    overflow:auto;
    padding-top:10px;
    margin-top:5px;
    width:400px;
    where width is the left site of the message box. Just adjusted to your template!
    Hope this helps
    br
    Ralf
This topic contains 8 replies, has 5 voices, and was last updated by  taiwi 16 years, 5 months ago.
