  • pradeep_rs Friend
    #190563
    How can i disable the Image Slideshow Feature in an artcile. I want to display images in a table but this slideshow is messing it up.
    Link – http://fdlta.org/atf/index.php/about-atf/executive-body
    That articles images are managed by the ja_Thumbnail plugin
    If you want to directly manage them then disable the plugin from plugin manager >> Ja_Thumbnail plugin
This topic contains 2 replies, has 2 voices, and was last updated by  pavit 11 years, 4 months ago.
