March 15, 2018 at 4:35 am #1112413Hi,
Could you share the FTP account also?
ssinha Friendssinha
- July 2014
- 12 times in 1 posts
March 15, 2018 at 1:07 pm #1112445This reply has been marked as private.Saguaros ModeratorSaguaros
March 16, 2018 at 8:43 am #1112487Hi Sunil,
The FTP account seems not work, could you update again?
And try opening the file: root/configuration.php and change the variable:
public $error_reporting = 'default';
to:
public $error_reporting = 'maximum';
Then try to login again, it should show the error message in blank page and you will know which one caused issue.
ssinha Friendssinha
- July 2014
March 16, 2018 at 12:23 pm #1112499This reply has been marked as private.Saguaros ModeratorSaguaros
March 17, 2018 at 2:35 am #1112522Hi,
I tried to enable the Error Reporting and saw the issue comes from Akeeba Backup extension:
Fatal error: Class 'FOF30\Container\Container' not found in ..../plugins/quickicon/akeebabackup/akeebabackup.php on line 225
There seems to be issue with their library, you should contact provider of this extension for further helps.
ssinha Friendssinha
- July 2014
March 17, 2018 at 11:35 am #1112528Thanks for your help Saguaros. The blank page issue upon logging in the backend related with Akeeba has been resolved. The megamenu issue, however, continues as I described above. This is what I was originally trying to fix it when this blank page issue came up. A similar post 2-3 years ago suggested a change in the mainnav.php and offered to download this file he had provided for the original poster. When I downloaded this file and replaced it with the original mainnav.php, this blank page issue came up.
Can you please look into this megamenu issue? Thanks for your help, Saguaros.
PS – Your backend credentials are still valid.
March 19, 2018 at 4:02 am #1112572Hi,
As I can see that there are numbers of Internal Server errors on that page: http://prntscr.com/it3lap
Pls make sure that you set the right permission for all files/folders on your site: File-644 and Folder-755
ssinha Friendssinha
- July 2014
March 19, 2018 at 3:15 pm #1112615Saguaros, thanks for your continued help. I have checked the permissions of all folders and (some) files, including /plugins/system/t3/admin/megamenu/js but I have not been able to find any permission error. Can you pinpoint which folder/file is having permission issue? Thanks.
March 20, 2018 at 8:07 am #1112638Hi,
Somehow, it notices error in the override of com_content, I updated this line:
JLoader::register('ContentHelperRoute', JPATH_SITE . '/components/com_content/helpers/route.php');
in the file: /templates/ja_teline_v/html/layouts/joomla/content/image/image.php
and the megamenu is showing fine now.
ssinha Friendssinha
- July 2014
March 20, 2018 at 4:31 pm #1112668Thank you very much Saguaros. Yes, it’s working fine now. Not sure what happened. Very much appreciate your help.
Regards,
Sunil
March 21, 2018 at 7:32 am #1112687Glad to hear that!
If you have new question, pls help us to post in our new forum: https://member.joomlart.com/forums/
This forum will be closed soon.
Have a nice day!!!
This topic contains 11 replies, has 2 voices, and was last updated by Saguaros 6 years, 9 months ago.
The topic ‘Urgent Help Needed – Trying to fix megamenu issue messed up backend login’ is closed to new replies.
