Pankaj Sharma Moderator
November 17, 2014 at 5:09 pm #555466HI please add user name and pass and in service config. in JA extension manager .
Update T3 and Joomla on your test site .
For Joomla site backup i suggest you to use Akeeba Backup component .
Here is linkNote : Don`t play with our live site , Always take backup of your site before any Update .
stazzy Friendstazzy
- 3 times in 1 posts
November 18, 2014 at 10:07 am #555580GOOD MORNING SIR. I HAV INSTALL AND STARTED THE SITE FROM THE BEGINING WITH JA NEX T3 BUT AM HAVING A LITTLE ISSUE. MY top-home 1 2 3 and sidebar 1 2 MODULE POSITIONS ARE NOT RESPONDING AFTER ASSINGIN IT. PLS WAT DO I DO? http://www.absradiotv.com
November 18, 2014 at 10:11 am #555582Good Morning stazzy can send me your site admin details via private message . i will check it for you .
If you started it from new install read user guide of template. it will helps you .
stazzy Friendstazzy
November 18, 2014 at 10:33 am #555585Ok sir. Hav sent the details
November 18, 2014 at 10:38 am #555586Hello you have selected Full width layout in for your template and it does not contain
top-home 1 2 3 and sidebar 1 2 .>>> http://prntscr.com/57kruw
Go to template manager >>> ja_nex_t3 – Default >>layout
and change the layout to sidebar -content . You can see all the module positions in the layout sections .
Hope it helps you1 user says Thank You to Pankaj Sharma for this useful post
stazzy Friendstazzy
November 18, 2014 at 10:46 am #555588You are the boss. Thank u very much
one last thing
this image i sent i am getin an error wen i wanna go to the back end. Can i hav the back end pls?
stazzy Friendstazzy
November 18, 2014 at 10:49 am #555589Pankaj Sharma ModeratorPankaj Sharma
November 18, 2014 at 10:53 am #555591ADD this code in your custom.css file
/template/your ja template/css/custom.css
add this code
.t3-mainnav .logo-image a {
background-image: none;
}if there is no custom.css file then create a file with name custom.css
stazzy Friendstazzy
November 19, 2014 at 1:12 am #555657Thanks Sir. it worked
November 19, 2014 at 4:43 am #555688<em>@stazzy 453685 wrote:</em><blockquote>custom.css does not exist sir.</blockquote>
Please create a file with name custom.css
in /template/your ja template/css/custom.css .
Let me know if it helps1 user says Thank You to Pankaj Sharma for this useful post
stazzy Friendstazzy
November 19, 2014 at 5:09 am #555696Pankaj Sharma ModeratorPankaj Sharma
November 19, 2014 at 5:29 am #555705Hi your site is working fine . its normal behave >> http://prntscr.com/57v5hg
also when i resize the window its working fine .>>> http://prntscr.com/57v5nh .
window resized is browser property. your site is working fine.1 user says Thank You to Pankaj Sharma for this useful post
stazzy Friendstazzy
November 19, 2014 at 5:52 am #555708Ok sir. thank u very much for ur help.
stazzy Friendstazzy
November 19, 2014 at 8:38 am #555742Sir I Am almost done wit the site. I noticed below d site I can’t see any link to switch from mobile to web view. Pls help me on that. Thanks?
November 19, 2014 at 8:41 am #555743<blockquote>Sir I Am almost done wit the site. I noticed below d site I can’t see any link to switch from mobile to web view. Pls help me on that. Thanks?</blockquote>
First i request you to open a new thread for a different problem .
Now its not problem you are using responsive template and it does not have this kind of options . its auto resize as per windows size .AuthorPostsThis topic contains 30 replies, has 2 voices, and was last updated by Pankaj Sharma 9 years, 11 months ago.
