  • arinus Friend
    #130433
    how to make the gallery in frontend of main menu gallery can show the image for 5 picture
    may be you can saw at http://www.deviantart.com in their category…
    and how to make a right click is disable for resgitered member…
    #257893
    I think you must write a module show at front-end to show as you want
    arinus Friend
    #257901
    can u told me where i can find the RS Gallery module Random, Most Votes, Most Popular, Highest Rated,
    i’m using J. 1.0.15
    #257953
    You can go to http://rsgallery2.net/ to find them, JA dont support them
    regards
This topic contains 4 replies, has 2 voices, and was last updated by  Sherlock 16 years, 5 months ago.
