August 9, 2008 at 11:16 am #132013
Hello friends , i have a big problem with my tamplate, i have very clientes, please help me.
http://www.zapmp3.com.brAugust 9, 2008 at 11:51 am #264677Please i heve very urgency, this error:
e Joomla * @copyright Copyright (C) 2005 – 2008 Open Source Matters. All rights reserved. * @license GNU/GPL, see LICENSE.php * Joomla! is free software. This version may have been modified pursuant * to the GNU General Public License, and as distributed it includes or * is derivative of works licensed under the GNU General Public License or * other free or open source software licenses. * See COPYRIGHT.php for copyright notices and details. */ // Set flag that this is a parent file define( ‘_JEXEC’, 1 ); define(‘JPATH_BASE’, dirname(__FILE__) ); define( ‘DS’, DIRECTORY_SEPARATOR ); require_once ( JPATH_BASE .DS.’includes’.DS.’defines.php’ ); require_once ( JPATH_BASE .DS.’includes’.DS.’framework.php’ ); JDEBUG ? $_PROFILER->mark( ‘afterLoad’ ) : null; /** * CREATE THE APPLICATION * * NOTE : */ $mainframe =& JFactory::getApplication(‘site’); /** * INITIALISE THE APPLICATION * * NOTE : */ // set the language $mainframe->initialise(); JPluginHelper::importPlugin(‘system’); // trigger the onAfterInitialise events JDEBUG ? $_PROFILER->mark(‘afterInitialise’) : null; $mainframe->triggerEvent(‘onAfterInitialise’); /** * ROUTE THE APPLICATION * * NOTE : */ $mainframe->route(); // authorization $Itemid = JRequest::getInt( ‘Itemid’); $mainframe->authorize($Itemid); // trigger the onAfterRoute events JDEBUG ? $_PROFILER->mark(‘afterRoute’) : null; $mainframe->triggerEvent(‘onAfterRoute’); /** * DISPATCH THE APPLICATION * * NOTE : */ $option = JRequest::getCmd(‘option’); $mainframe->dispatch($option); // trigger the onAfterDispatch events JDEBUG ? $_PROFILER->mark(‘afterDispatch’) : null; $mainframe->triggerEvent(‘onAfterDispatch’); /** * RENDER THE APPLICATION * * NOTE : */ $mainframe->render(); // trigger the onAfterRender events JDEBUG ? $_PROFILER->mark(‘afterRender’) : null; $mainframe->triggerEvent(‘onAfterRender’); /** * RETURN THE RESPONSE */ echo JResponse::toString($mainframe->getCfg(‘gzip’));
Hieu Nguyen AdminHieu Nguyen
- November 2005
- 61 times in 1 posts
August 9, 2008 at 12:19 pm #264678Did you use a QuickStart package or set up from a new one?
All the team is on weekend now, so sorry for any delay in answer.
August 9, 2008 at 12:24 pm #264681Thank you, I used quickstart and I installed in another directory, when I tried to change gave error, as I can resolve that!
- November 2005
August 9, 2008 at 12:33 pm #264682It’s seem that the problem is from your server. The one in our team with technical knowledge in Server Configuration is currently on holiday. I will contact him as soon as possible to see if he can help you in this case. So sorry for your inconvenient!
August 9, 2008 at 12:37 pm #264683Hello friend, the server i ok, see: http://www.zapmp3.com.br/zapmp3, but, i has problem when I tried change directory
- November 2005
August 9, 2008 at 12:40 pm #264684<em>@zapmp3 72661 wrote:</em><blockquote>Hello friend, the server i ok, see: http://www.zapmp3.com.br/zapmp3, but, i has problem when I tried change directory</blockquote>
Do you mean changing from http://www.zapmp3.com.br/zapmp3 to http://www.zapmp3.com.br ?
August 9, 2008 at 12:41 pm #264686yes, please help me
- November 2005
August 9, 2008 at 12:44 pm #264687Please PM me your configuration.php.
August 9, 2008 at 12:46 pm #264688ok, a moment
August 9, 2008 at 12:52 pm #264690i sent configuration .php
- November 2005
August 9, 2008 at 1:09 pm #264693Please check your PM! Thank for your understanding and patience!
August 9, 2008 at 1:11 pm #264694thank you by try help me, I am changing from servant and in a little while I placed here the result
- November 2005
August 9, 2008 at 1:22 pm #264697I’ve called the one who can help you. Hope he will be here soon! At this time, I’ll wait for your result and hope you’ll get your success. 🙂
This topic contains 18 replies, has 3 voices, and was last updated by zapmp3 16 years, 4 months ago.
