  • frodestian Friend
    #195891
    My page http://www.teleposten.no (its in norwegian) has over night encounterd some link issues.
    When i try to go into an article from the front page, i se the URL change, but page stays at front page..
    Anyone else had this happend? If so, how did you fix it?
    I have tryed to delete the last articles i’ve put in, but that did not help.
    Kind regards,
    Frode
    Hi Frode,
    That article may not be assigned to any menu item, please try to create a new menu item or using an existing one and assign that article to. It should direct to article detailed page then.
    Best
    frodestian Friend
    #527299
    Saguaros, all articles can not be opened from the front page, if i go to the kategori from the menu i can access them, just not from the front page at all…
    It seems to be working now, please let me know if you need further helps.
This topic contains 4 replies, has 2 voices, and was last updated by  Saguaros 10 years, 9 months ago.
