  • wsmcos89 Friend
    #148979
    In my site:
    http://wsmcosmeticos.com.br/
    When I go to a product, my site is showing this mensage:
    Warning: require_once(/home/wsmcosmeticos/www/components/com_virtuemart/helpers/route.php) [function.require-once]: failed to open stream: No such file or directory in /home/wsmcosmeticos/www/modules/mod_ja_contentscroll/helper.php on line 8
    Fatal error: require_once() [function.require]: Failed opening required ‘/home/wsmcosmeticos/www/components/com_virtuemart/helpers/route.php’ (include_path=’.:/usr/local/lib/php’) in /home/wsmcosmeticos/www/modules/mod_ja_contentscroll/helper.php on line 8
    I opened a ticket :
    Ticket ID: FRV-153395
    And you said:
    Please try as following for this issues:
    Open modulesmod_contentscrollhelper.php file
    Back-up this file then replace it by attachment file
    Hope this would help !
    Sincerely,
    Hoang Quoc Dat
    JoomlArt.com Customer Service.
    I did that, but it is not working
    I am very disappointed with this template
    Dear guy!
    I accessed the administrator and turned on the ja_contentscroll module, i could not see any problems same as you said.
    pls kindly check for me
    #334017
    Hi Guy,
    Please check on that ticket,I Have just reply again!
This topic contains 3 replies, has 3 voices, and was last updated by  Sherlock 14 years, 10 months ago.
