  • juanci Friend
    #125447
    Dear friends.
    I’ve installed Genista theme and I have problems to put slideshow or content show modules into the slideshow position. I’ve defined this position into the template position and I’ve referenced it from the module.
    The thisng is that nothing is displayed in this position. I’ve not modified anything on the template.
    I need to use this position and I’ve change the theme of my site to change to this template.
    Do you have any clue? My joomla version is 1.0.13
    Cheers
    Juan
    Michael Casha Friend
    #238153
    As per the forum rules, do you have a live site url?
    juanci Friend
    #238172
    Hi Michael
    Sorry, I forgot to include it. http://www.serviciosalovera.com/index.php
    At this moment, and as I change the template yesterday, everything seems like a mess (modules are not still in the positions they will be). Howeve, seeing the url can help you.
    Thanks in advance.
    Juan
    juanci Friend
    #238174
    Hi again, Michael
    As a possible clue. It seems that Joomla doesn’t recognize the module position “slideshow”, although I put it in the “Module Positions”. I’ve tried to position other components in the slideshow pos and it also doesn’t work.
    The modules you provided me with the themes seem to work well in other positions.
    I’m sure I’m doing something wrong but I can’t see it.
    Cheers
    Juan
This topic contains 4 replies, has 2 voices, and was last updated by  juanci 16 years, 11 months ago.
