December 12, 2008 at 5:59 pm #136193
[FONT=”Arial Black”]Please help[/FONT]
I getting this message anytime I click on any link on my home page
http://www.soscarrepair.com
thus I can not go anywhereNot Found
The requested URL /example-pages.html was not found on this server.
Additionally, a 404 Not Found error was encountered while trying to use an ErrorDocument to handle the request.
Apache/2.2.10 (Unix) mod_ssl/2.2.10 OpenSSL/0.9.8i DAV/2 mod_auth_passthrough/2.1 mod_bwlimited/1.4 FrontPage/5.0.2.2635 Server at soscarrepair.com Port 80I did email my bluehost and they emailed me this:
I noticed that your /public_html/.htaccess file is empty. Joomla has its own code that needs to reside in the .htaccess. I temporarily renamed /public_html/.htaccess.bak to /public_html/.htaccess as it appears to have the right coding at first glance, but the problem persisted. You do have friendly URLs enabled, right? If you could please provide the login info. for http://soscarrepair.com/administrator hopefully we’ll be able to troubleshoot this from the backend.so I did called them but then they say that joomla is third party and I have to solve it from joomla.
Do you know what to do? I like to learn about joomla and convert my site http://www.sosdent.com to joomla for over year now >:( (there is always some excusess I do) and now I would like to get going on.
things like these discourage me little bit. I know it is just problem sovling and on my own I will not be able to solve it fast.
Does some of you know what to do, so I can start working and learning about joomla.thank you in advance, even if you can not help me, thanks for reading, maybe you know about some tutorial or something.
Best David
jay973 Friendjay973
- October 2008
- 105 times in 68 posts
December 12, 2008 at 6:11 pm #282634Have you enabled Search Engine Friendly URLs, Use Apache mod_rewrite, Add suffix to URLs in the Global Configuration or added any SEF component? If you have, disable them and you should be up and running again.
Hope this helps,
Jason.1 user says Thank You to jay973 for this useful post
December 12, 2008 at 6:29 pm #282639Hi Jason
thank you for your quick respond, I am so new, that language what you speak doesn’t give me much sense :confused:
can you let my know step by step what to click
for example:
Global Configuration >site> etcI think I got all what you said, but not totally sure,
I have snap shot of my global configuration. I hope that will help.
jay973 Friendjay973
- October 2008
December 12, 2008 at 6:36 pm #282643Hi,
You have all the ‘SEO Settings’ (Right side of the screen) set to ‘Yes’ at the moment. Set them to ‘No’ and you should be fine.Hope this helps,
Jason
December 12, 2008 at 7:14 pm #282654Jason, I did that, but I still got this message
404 – Article #27 not found
You may not be able to visit this page because of:1. an out-of-date bookmark/favourite
2. a search engine that has an out-of-date listing for this site
3. a mistyped address
4. you have no access to this page
5. The requested resource was not found.
6. An error has occurred while processing your request.Please try one of the following pages:
* Home Page
If difficulties persist, please contact the System Administrator of this site.
is there any default setting or something I can do to solve this without loosing all my articles?
jay973 Friendjay973
- October 2008
December 12, 2008 at 7:29 pm #282657No I didn’t do any of those, I using mozila but not sure how to delete history cookies. and sh404SEF I have no clue where it did come from.
Jason are there people who can solve this for me? like going to site and remove that problem?
thanks for all your help, this is good help, I wish we can solve thsi togetherjay973 Friendjay973
- October 2008
December 12, 2008 at 7:43 pm #282660Hi,
To refresh firefox, press F5
I’ve found a post on the Joomla forums about your problem and they say it could be related to the article expiry dates:
http://forum.joomla.org/viewtopic.php?p=1489507If that doesn’t work it may be worth contacting JA staff/Mods like:
JA Developer
http://www.joomlart.com/forums/reply/a-work-of-joomlart-7/
or
hainn84
http://www.joomlart.com/forums/topic/content-2/They are very helpful and may take a look inside your site for you.
Hope this helps,
Jason
December 12, 2008 at 8:00 pm #282665Thank you I will see what I can do solve this soon as possible.
you good luck to you JayAnonymous ModeratorJA Developer
- 2008 times in 1700 posts
December 13, 2008 at 2:01 am #282710Hi sosdent,
I have checked your website.And i saw that:
When i clicked on Services menu, i found your issue.I logined to administrator, check the article, which on your link but could not find this article.When i clicked other menu, i saw articles.
Please try to check again, sure that the link to article is correct.
AuthorPostsViewing 10 posts - 1 through 10 (of 10 total)This topic contains 10 replies, has 3 voices, and was last updated by Anonymous 15 years, 9 months ago.
URL not found and link problems
