  • shemeam Friend
    #206176
    Hello
    is it possible to use the ACM ‘Bar’ style 2 in the same way as the masthead works.
    I would like to use it to pick up the menu title depending on which page it is on, rather than creating a bar for each page.
    Te masthead is too deep (vertical height).
    Any ideas welcomed.
    Shemeam
    Hi Shemeam,
    Unfortunately, ACM – Bar style 2 doesn’t support that feature. I think you can change the masthead module instead.
    Hi Shemeam,
    shemeam Friend
    #569925
    Thanks for your reply Saguaros
    Is there a custom code I can use to change the vertical height of the masthead, and the colour?
    Shemeam
    You can post the URL of page where you’re using the masthead here, I will take a look
    shemeam Friend
    #570529
    Hi Saguaros
    It is not a working site at the moment, only in my head, so it was just a question pre-build.
    Shemeam
    Let us know if it occurs in your live site 🙂
This topic contains 9 replies, has 2 voices, and was last updated by  Saguaros 9 years, 6 months ago.
