  • jesflow Friend
    #158828
    Hi there-
    Used the quickstart on localhost, no problems. Uploaded the full demo content to my server to edit there.
    Upon uploading, the mainmenu that shows in the top.mainnav position of the template is not the same as on the localhost. Localhost copy looks just like your demo. The uploaded version is showing the topmenu in the top.mainnav position instead of the mainmenu.
    We made no changes from the local copy to the copy on the server so I have NO IDEA what would cause this. Thoughts?
    aman204 Friend
    #372066
    Will it be possible for you to please pm me superadmin details to take closer look
    jesflow Friend
    #372109
    Details sent, thank you for looking!
    And if you happen to know what would cause the Error loading feed data error you see when you first log in, that’d be great. In front end, if you go to news page, you see * Error loading feed data. * Error. Feed not retrieved. Just using the stock entries from quickstart here as well.
    aman204 Friend
    #372279
    Please view now 🙂
    The menu type had to be changed in Menu settings tab in template parameters
    jesflow Friend
    #372283
    Well I was blind. Thank you SO much!
This topic contains 5 replies, has 2 voices, and was last updated by  jesflow 13 years, 11 months ago.
