  • alibrando Friend
    #119211
    According to userguide.html I need to edit my index.php to make different changes to my site (ie menu type, and font size) but no where in my index.php file do I fine the variables to change. Can anyone help me? Thanks.
    David
    Michael Casha Friend
    #216033
    You’ll see in index.php at about line 18 this:
    # TEMPLATE CONFIGURATIONS ##########
    #support extra color themes
    $ja_color_themes = array(‘blue’,’orange’,’green’); // You can add more color array if needed
    # Change the width of the template
    $ja_width_default = ‘narrow’; // ‘narrow’: 800×600; ‘wide’: 1024×768; ‘auto’: fluid width
    # default color
    $ja_color_default = ‘blue’; //blank for default, else pick one of in extra color themes $ja_color_themes
    #font size default
    $ja_font_size_default = 3;
    # Enable users option
    $ja_tool = 3; // 0: disable all; 1: disable color, enable screen; 2: enable color, disable screen; 3: enable all.
    # Choose your prefer Menu Type
    $ja_menutype = 1; // 1: Split Menu; 2: Son of Suckerfish Dropdown Menu; 3: Transmenu;
    # END: TEMPLATE CONFIGURATIONS ##########
    They are the settings you need to alter.
    alibrando Friend
    #216052
    This is my index.php
    <blockquote><?php
    * @version $Id: index.php 6022 2006-12-18 22:30:07Z friesengeist $
    * @package Joomla
    * @copyright Copyright (C) 2005 Open Source Matters. All rights reserved.
    * @license http://www.gnu.org/copyleft/gpl.html GNU/GPL, see LICENSE.php
    * Joomla! is free software. This version may have been modified pursuant
    * to the GNU General Public License, and as distributed it includes or
    * is derivative of works licensed under the GNU General Public License or
    * other free or open source software licenses.
    * See COPYRIGHT.php for copyright notices and details.
    // Set flag that this is a parent file
    define( ‘_VALID_MOS’, 1 );
    // checks for configuration file, if none found loads installation page
    if (!file_exists( ‘configuration.php’ ) || filesize( ‘configuration.php’ ) < 10) {
    $self = rtrim( dirname( $_SERVER[‘PHP_SELF’] ), ‘/\’ ) . ‘/’;
    header(“Location: http://” . $_SERVER[‘HTTP_HOST’] . $self . “installation/index.php” );
    exit();
    require( ‘globals.php’ );
    require_once( ‘configuration.php’ );
    // SSL check – $http_host returns <live site url>:<port number if it is 443>
    $http_host = explode(‘:’, $_SERVER[‘HTTP_HOST’] );
    if( (!empty( $_SERVER[‘HTTPS’] ) && strtolower( $_SERVER[‘HTTPS’] ) != ‘off’ || isset( $http_host[1] ) && $http_host[1] == 443) && substr( $mosConfig_live_site, 0, 8 ) != ‘https://’ ) {
    $mosConfig_live_site = ‘https://’.substr( $mosConfig_live_site, 7 );
    require_once( ‘includes/joomla.php’ );
    //Installation sub folder check, removed for work with SVN
    if (file_exists( ‘installation/index.php’ ) && $_VERSION->SVN == 0) {
    define( ‘_INSTALL_CHECK’, 1 );
    include ( $mosConfig_absolute_path .’/offline.php’);
    exit();
    // displays offline/maintanance page or bar
    if ($mosConfig_offline == 1) {
    require( $mosConfig_absolute_path .’/offline.php’ );
    // load system bot group
    $_MAMBOTS->loadBotGroup( ‘system’ );
    // trigger the onStart events
    $_MAMBOTS->trigger( ‘onStart’ );
    if (file_exists( $mosConfig_absolute_path .’/components/com_sef/sef.php’ )) {
    require_once( $mosConfig_absolute_path .’/components/com_sef/sef.php’ );
    } else {
    require_once( $mosConfig_absolute_path .’/includes/sef.php’ );
    require_once( $mosConfig_absolute_path .’/includes/frontend.php’ );
    // retrieve some expected url (or form) arguments
    $option = strval( strtolower( mosGetParam( $_REQUEST, ‘option’ ) ) );
    $Itemid = intval( mosGetParam( $_REQUEST, ‘Itemid’, null ) );
    if ($option == ”) {
    if ($Itemid) {
    $query = “SELECT id, link”
    . “n FROM #__menu”
    . “n WHERE menutype = ‘mainmenu'”
    . “n AND id = ” . (int) $Itemid
    . “n AND published = 1”
    $database->setQuery( $query );
    } else {
    . “n FROM #__menu”
    . “n ORDER BY parent, ordering”
    $database->setQuery( $query, 0, 1 );
    $menu = new mosMenu( $database );
    if ($database->loadObject( $menu )) {
    $Itemid = $menu->id;
    $link = $menu->link;
    if (($pos = strpos( $link, ‘?’ )) !== false) {
    $link = substr( $link, $pos+1 ). ‘&Itemid=’.$Itemid;
    parse_str( $link, $temp );
    /** this is a patch, need to rework when globals are handled better */
    foreach ($temp as $k=>$v) {
    $GLOBALS[$k] = $v;
    $_REQUEST[$k] = $v;
    if ($k == ‘option’) {
    $option = $v;
    if ( !$Itemid ) {
    // when no Itemid give a default value
    $Itemid = 99999999;
    // mainframe is an API workhorse, lots of ‘core’ interaction routines
    $mainframe = new mosMainFrame( $database, $option, ‘.’ );
    $mainframe->initSession();
    // trigger the onAfterStart events
    $_MAMBOTS->trigger( ‘onAfterStart’ );
    // checking if we can find the Itemid thru the content
    if ( $option == ‘com_content’ && $Itemid === 0 ) {
    $id = intval( mosGetParam( $_REQUEST, ‘id’, 0 ) );
    $Itemid = $mainframe->getItemid( $id );
    /** do we have a valid Itemid yet?? */
    if ( $Itemid === 0 ) {
    /** Nope, just use the homepage then. */
    $query = “SELECT id”
    . “n FROM #__menu”
    $Itemid = $database->loadResult();
    // patch to lessen the impact on templates
    if ($option == ‘search’) {
    $option = ‘com_search’;
    // loads english language file by default
    if ($mosConfig_lang==”) {
    $mosConfig_lang = ‘english’;
    include_once( $mosConfig_absolute_path .’/language/’ . $mosConfig_lang . ‘.php’ );
    // frontend login & logout controls
    $return = strval( mosGetParam( $_REQUEST, ‘return’, NULL ) );
    $message = intval( mosGetParam( $_POST, ‘message’, 0 ) );
    if ($option == ‘login’) {
    $mainframe->login();
    // JS Popup message
    if ( $message ) {
    <script language=”javascript” type=”text/javascript”>
    alert( “<?php echo addslashes( _LOGIN_SUCCESS ); ?>” );
    </script>
    <?php
    if ( $return && !( strpos( $return, ‘com_registration’ ) || strpos( $return, ‘com_login’ ) ) ) {
    // checks for the presence of a return url
    // and ensures that this url is not the registration or login pages
    // If a sessioncookie exists, redirect to the given page. Otherwise, take an extra round for a cookiecheck
    if (isset( $_COOKIE[mosMainFrame::sessionCookieName()] )) {
    mosRedirect( $return );
    } else {
    mosRedirect( $mosConfig_live_site .’/index.php?option=cookiecheck&return=’ . urlencode( $return ) );
    } else {
    // If a sessioncookie exists, redirect to the start page. Otherwise, take an extra round for a cookiecheck
    mosRedirect( $mosConfig_live_site .’/index.php’ );
    } else {
    mosRedirect( $mosConfig_live_site .’/index.php?option=cookiecheck&return=’ . urlencode( $mosConfig_live_site .’/index.php’ ) );
    } else if ($option == ‘logout’) {
    $mainframe->logout();
    // JS Popup message
    if ( $message ) {
    alert( “<?php echo addslashes( _LOGOUT_SUCCESS ); ?>” );
    </script>
    <?php
    // and ensures that this url is not the registration or logout pages
    } else {
    mosRedirect( $mosConfig_live_site.’/index.php’ );
    } else if ($option == ‘cookiecheck’) {
    // No cookie was set upon login. If it is set now, redirect to the given page. Otherwise, show error message.
    } else {
    mosErrorAlert( _ALERT_ENABLED );
    /** get the information about the current user from the sessions table */
    $my = $mainframe->getUser();
    // detect first visit
    $mainframe->detect();
    // set for overlib check
    $mainframe->set( ‘loadOverlib’, false );
    $gid = intval( $my->gid );
    // gets template for page
    $cur_template = $mainframe->getTemplate();
    /** temp fix – this feature is currently disabled */
    /** @global A places to store information from processing of the component */
    $_MOS_OPTION = array();
    // precapture the output of the component
    require_once( $mosConfig_absolute_path . ‘/editor/editor.php’ );
    ob_start();
    if ($path = $mainframe->getPath( ‘front’ )) {
    $task = strval( mosGetParam( $_REQUEST, ‘task’, ” ) );
    $ret = mosMenuCheck( $Itemid, $option, $task, $gid );
    if ($ret) {
    require_once( $path );
    } else {
    mosNotAuth();
    } else {
    header( ‘HTTP/1.0 404 Not Found’ );
    echo _NOT_EXIST;
    $_MOS_OPTION[‘buffer’] = ob_get_contents();
    ob_end_clean();
    initGzip();
    header( ‘Expires: Mon, 26 Jul 1997 05:00:00 GMT’ );
    header( ‘Last-Modified: ‘ . gmdate( ‘D, d M Y H:i:s’ ) . ‘ GMT’ );
    header( ‘Cache-Control: no-store, no-cache, must-revalidate’ );
    header( ‘Cache-Control: post-check=0, pre-check=0’, false );
    header( ‘Pragma: no-cache’ );
    // display the offline alert if an admin is logged in
    if (defined( ‘_ADMIN_OFFLINE’ )) {
    include( $mosConfig_absolute_path .’/offlinebar.php’ );
    // loads template file
    if ( !file_exists( $mosConfig_absolute_path .’/templates/’. $cur_template .’/index.php’ ) ) {
    echo _TEMPLATE_WARN . $cur_template;
    } else {
    require_once( $mosConfig_absolute_path .’/templates/’. $cur_template .’/index.php’ );
    echo ‘<!– ‘. time() .’ –>’;
    // displays queries performed for page
    if ($mosConfig_debug) {
    echo $database->_ticker . ‘ queries executed’;
    echo ‘<pre>’;
    foreach ($database->_log as $k=>$sql) {
    echo $k+1 . “n” . $sql . ‘<hr />’;
    echo ‘</pre>’;
    doGzip();
    ?></blockquote>
    ShannonN Friend
    #216056
    alibrando;10177This is my index.php
    Hi David
    You need to look at the templates/antares folder and the index.php file inside there
    the one you have tehre is the main joomla index.php
    ShannonN
    alibrando Friend
    #216059
    thanks! thats the info i was looking for!
    David
This topic contains 5 replies, has 3 voices, and was last updated by  alibrando 17 years, 9 months ago.
