  • annieb Friend
    #199851
    I wanted to use a module class suffux to add some layout to the module (add dropshadow to image which is used in JA Image Hotspot), but everytime I assign a module class suffix to the module, the view of the module in the front-end collapses. For example, when I choose to position the drop-down menu in the middle left of the image and assign a module class suffix, the drop-down is moved to the top left outside the image, even when the module class suffix in css is totally empty (no css defined, only the class). Does anybody have an idea why this happens?
    I can add the drop shadow in style.css, but I’d much rather do it using a module class suffix.
    Thanks!
    Thanh Nguyen Viet Friend
    #543571
    Please add one space before value that you entered on Module class suffix field, then it will add new class for div wrapper element of JA Image Hotspot module.
    E.g: ” dropsharow” (without quotes)
    Then you can style for this suffix by adding css code with prefix below
    .jai-map-wrap.dropsharow
    FYI: If you add suffix without space before, then class name of div wrapper will be changed, and it is a cause of break style.
    annieb Friend
    #544577
    I will try that, thanks!
This topic contains 3 replies, has 2 voices, and was last updated by  annieb 10 years, 4 months ago.
