  • micheltorres Friend
    #186788
    Is there any easy way of using another commenting system (JComments or Komento), showing the number of comments right after the number of hits?
    Thank you
    HeR0 Friend
    #489999
    Dear Micheltorres,
    Unfortunately, we are not sure if your site will still work well if you change commenting system. Because in this template, we have fixed article ajax loading with Disqus plugin. However, no harm in trying it out, The articles Ajax loading issue is from Disqus but may be it will go with change in commenting system. 🙂
    <em>@micheltorres 369063 wrote:</em><blockquote>Hello,
    Thank you</blockquote>
This topic contains 2 replies, has 2 voices, and was last updated by  HeR0 11 years, 9 months ago.
