icbl Friend
icbl
- December 2010
- 7 times in 1 posts
December 23, 2010 at 11:33 am #157809Hi,
I’d like to reduce padding size from left and right. How can I do that?
1- I’d like to have JA Purity 2’s style, framed title as you can see in the picture
2- How can I move Read More button to the location shown.Ninja Lead ModeratorNinja Lead
- November 2014
- 3854 times in 3563 posts
December 24, 2010 at 4:58 am #368427Hi icbl,
You can change the interface of this short article displaying by modifying the file:
templatesja_community_plushtmlcom_contentfrontpagedefault_item.php
along with neccessary css files.for instance, for the 2 requirements above, change default_item.php with this content:
<?php
JA Purity II for Joomla 1.5
#Copyright (C) 2004-2009 J.O.O.M Solutions Co., Ltd. All Rights Reserved.
#@license - GNU/GPL, http://www.gnu.org/copyleft/gpl.html
#Author: J.O.O.M Solutions Co., Ltd
#Websites: http://www.joomlart.com - http://www.joomlancers.com
*/// no direct access
defined('_JEXEC') or die('Restricted access'); ?><?php if ($this->user->authorize('com_content', 'edit', 'content', 'all') || $this->user->authorize('com_content', 'edit', 'content', 'own')) : ?>
<div class="contentpaneopen_edit<?php echo $this->escape($this->item->params->get( 'pageclass_sfx' )); ?>" style="float: left;">
<?php echo JHTML::_('icon.edit', $this->item, $this->item->params, $this->access); ?>
</div>
<?php endif; ?>
<div class="contentpaneopen<?php echo $this->escape($this->item->params->get( 'pageclass_sfx' )); ?>"><?php if ($this->item->params->get('show_title')) : ?>
<h2 class="contentheading<?php echo $this->escape($this->item->params->get( 'pageclass_sfx' )); ?>">
<?php if ($this->item->params->get('link_titles') && $this->item->readmore_link != '') : ?>
<a href="<?php echo $this->item->readmore_link; ?>" class="contentpagetitle<?php echo $this->escape($this->item->params->get( 'pageclass_sfx' )); ?>">
<?php echo $this->escape($this->item->title); ?>
</a>
<?php else : ?>
<?php endif; ?>
</h2>
<?php endif; ?><?php if (!$this->item->params->get('show_intro')) :
echo $this->item->event->afterDisplayTitle;
endif; ?><?php
if (
($this->item->params->get('show_create_date'))
|| (($this->item->params->get('show_author')) && ($this->item->author != ""))
|| (($this->item->params->get('show_section') && $this->item->sectionid) || ($this->item->params->get('show_category') && $this->item->catid))
|| ($this->item->params->get('show_pdf_icon') || $this->item->params->get('show_print_icon') || $this->item->params->get('show_email_icon'))
|| ($this->item->params->get('show_url') && $this->item->urls)
<div class="article-tools clearfix"><div class="article-meta">
<?php if ($this->item->params->get('show_create_date')) : ?>
<span class="createdate">
<?php echo JHTML::_('date', $this->item->created, JText::_('DATE_FORMAT_LC2')); ?>
</span>
<?php endif; ?><?php if (($this->item->params->get('show_author')) && ($this->item->author != "")) : ?>
<span class="createby">
<?php JText::printf(($this->item->created_by_alias ? $this->escape($this->item->created_by_alias) : $this->escape($this->item->author)) ); ?>
</span>
<?php endif; ?><?php if (($this->item->params->get('show_section') && $this->item->sectionid) || ($this->item->params->get('show_category') && $this->item->catid)) : ?>
<?php if ($this->item->params->get('show_section') && $this->item->sectionid && isset($this->item->section)) : ?>
<span class="article-section">
<?php if ($this->item->params->get('link_section')) : ?>
<?php echo '<a href="'.JRoute::_(ContentHelperRoute::getSectionRoute($this->item->sectionid)).'">'; ?>
<?php endif; ?>
<?php echo $this->escape($this->item->section); ?>
<?php echo '</a>'; ?>
<?php endif; ?>
<?php if ($this->item->params->get('show_category')) : ?>
<?php echo ' - '; ?>
<?php endif; ?>
</span>
<?php endif; ?>
<?php if ($this->item->params->get('show_category') && $this->item->catid) : ?>
<?php if ($this->item->params->get('link_category')) : ?>
<?php echo '<a href="'.JRoute::_(ContentHelperRoute::getCategoryRoute($this->item->catslug, $this->item->sectionid)).'">'; ?>
<?php endif; ?>
<?php echo $this->escape($this->item->category); ?>
<?php endif; ?>
</span>
<?php endif; ?>
<?php endif; ?>
</div><?php if ($this->item->params->get('show_pdf_icon') || $this->item->params->get('show_print_icon') || $this->item->params->get('show_email_icon')) : ?>
<div class="buttonheading">
<?php if ($this->item->params->get('show_email_icon')) : ?>
<span>
<?php echo JHTML::_('icon.email', $this->item, $this->item->params, $this->access); ?>
</span>
<?php endif; ?><?php if ( $this->item->params->get( 'show_print_icon' )) : ?>
<span>
<?php echo JHTML::_('icon.print_popup', $this->item, $this->item->params, $this->access); ?>
</span>
<?php endif; ?><?php if ($this->item->params->get('show_pdf_icon')) : ?>
<span>
<?php echo JHTML::_('icon.pdf', $this->item, $this->item->params, $this->access); ?>
</span>
<?php endif; ?>
</div>
<?php endif; ?><?php if ($this->item->params->get('show_url') && $this->item->urls) : ?>
<span class="article-url">
<a href="http://<?php echo $this->escape($this->item->urls) ; ?>" target="_blank"><?php echo $this->escape($this->item->urls); ?></a>
</span>
<?php endif; ?></div>
<?php endif; ?><?php echo $this->item->event->beforeDisplayContent; ?>
<div class="article-content">
<?php if (isset ($this->item->toc)) : ?>
<?php echo $this->item->toc; ?>
<?php endif; ?>
<?php echo $this->item->text; ?>
</div><?php if ( intval($this->item->modified) != 0 && $this->item->params->get('show_modify_date')) : ?>
<span class="modifydate">
<?php echo JText::sprintf('LAST_UPDATED2', JHTML::_('date', $this->item->modified, JText::_('DATE_FORMAT_LC2'))); ?>
</span>
<?php endif; ?><?php if ($this->item->params->get('show_readmore') && $this->item->readmore) : ?>
<a href="<?php echo $this->item->readmore_link; ?>" title="<?php echo $this->escape($this->item->title); ?>" class="readon<?php echo $this->escape($this->item->params->get('pageclass_sfx')); ?>">
<?php if ($this->item->readmore_register) : ?>
<span><?php echo JText::_('Register to read more...'); ?></span>
<?php else : ?>
<span><?php echo JText::_('Read more...'); ?></span>
<?php endif; ?>
</a>
<?php echo $this->item->event->afterDisplayContent; ?>
open \templatesja_community_pluscsstemplate.css, change :
.article-tools {
background: url(../images/gline.gif) no-repeat left top;
padding: 10px 0 0 0;
}to:
.article-tools {
background: none repeat scroll 0 0 #F6F6F6;
border: 1px solid #DDDDDD;
clear: both;
color: #999999;
display: block;
line-height: normal;
margin: 0 0 10px;
padding: 5px;
position: relative;
}and you can have more detail modifications as you wish.
This topic contains 2 replies, has 2 voices, and was last updated by Ninja Lead 14 years ago.
