  • alandavison Friend
    #1059722
    I wish to be able to utilize Font Awesome fonts when building blocks within the AMC for the Company template. Can you please assist?
    Pankaj Sharma Moderator
    #1059763
    may I know with a screenshot and module style how you want to display the icons in the ACM module?
    alandavison Friend
    #1059924
    The module is Features Intro: Style 1 however, I would like to utilize Font Awesome (and even ionicons) within all ACM modules types and styles if possible.
    Thank you.
    #1060109
    In this case you have to do custom work in the ACM files to define the new files.
    You can find the acm files in the template folder /acm/feature intro folder and have to define new code for the fonts.
    alandavison Friend
    #1060485
    Thank you. Unfortunately, I am not a skilled programmer (which is why I am using your product). In the past, you were able to enable utilizing font awesome fonts within the ACM for the Uber template. Can this not be done for Company as well?
    #1060567
    In this template its doesn’t come with icons.
    Add a new features in pre made style took effort and time to define new code and style for it. This is something that doesn’t under the support scope.
    You can use JA Uber acm style in othet template.
    If you want to customize this template i suggest you to hire a developer for such tasks.
This topic contains 5 replies, has 2 voices, and was last updated by  Pankaj Sharma 7 years, 2 months ago.
