Ch1vpH Friend
Ch1vpH
- February 2016
August 11, 2016 at 8:06 pm #959185Hi – Can you please let me know, how I can use the Statistics Block in the JA ACM and other blocks as I only see 7 of the 15 blocks available in the Healthcare template.
Thanks for any advise in advance!
pavit Moderatorpavit
August 11, 2016 at 8:18 pm #959189Hi
JA ACM Module for ja_healthcare template has only 7 blocks type as you can see from image below , where you are seeing it has 15 block ? and to which statistics module are you referring ?
Ch1vpH FriendCh1vpH
- February 2016
August 11, 2016 at 8:33 pm #959198Ok
That documentation is referring to Uber template it has from default already all that ja acm modules ready to use .
Ja Healthcare template at the same way has only 7 ja acm modules blocks ready to be used in it , ready means that all style and settings are already included and specifically customized for the ja healthcare template , you can use if you want also other blocks into ja healthcare template following documentation
HERE
but it will require some minor css adjustments through custom.css file to be adapted correctly at your templateHope this clarified your question.
AuthorPostsViewing 4 posts - 1 through 4 (of 4 total)This topic contains 3 replies, has 2 voices, and was last updated by pavit 8 years, 3 months ago.
Using JA ACM Statistics Style and other blocks
