Viewing 15 posts - 1 through 15 (of 25 total)
  • umio Friend
    #206990
    when i want use JA ACM timeline modul on postion container-box the description text
    http://prntscr.com/7deobj
    is view only by first time by other time can not view, the description text
    http://prntscr.com/7del2i
    when use on position spa-home is all description to view,
    http://prntscr.com/7demel
    please how fix this issue?
    Thank you.
    Umio
    Adam M Moderator
    #573440
    Hi Umio,
    Could you please provide a temporary admin account via private reply so I can have a closer look at the problem ?
    umio Friend
    #575786
    please, can any fix this problem on Uber template?
    umio Friend
    #642115
    umio Friend
    #740775
    Adam M Moderator
    #575903
    Hi @umio,
    Adam M Moderator
    #642232
    Hi @umio,
    Adam M Moderator
    #740892
    Hi @umio,
    Adam M Moderator
    #577641
    Hi @umio,
    Sorry for the delay in getting back to you. I checked your site and see that you put that module inside a tab and it works fine, could you please confirm your status ?
    Adam M Moderator
    #643935
    Hi @umio,
    Adam M Moderator
    #742570
    Hi @umio,
    umio Friend
    #645246
    Hi Adam,
    no, nothing is fixed and this issue is the same…
    Adam M Moderator
    #645325
    Hi @umio,
    Please open file templatesubercsscustom.css (if you don’t have this file, just create a new one) then add this code :
    .acm-timeline.style-1 .timeline-list .item-row .timeline-item .item-title ~ p {
    display: block !important;
    Adam M Moderator
    #743948
    Hi @umio,
    umio Friend
    #718979
    Hi Adam,
    thx, get done, but nothing has changed
    http://prntscr.com/8vj9si
    this is on backend
    http://prntscr.com/8vjc4u
    please repait this issue. Thank you.
    umio
This topic contains 25 replies, has 2 voices, and was last updated by  Adam M 9 years, 1 month ago.
