  • davidr Friend
    #118741
    Hi Guys
    Hot having any luck using the JA Header module with Zebrina, cannot get it to publish in any of Module 7,8,9 positions.
    Any hints?
    ha le-viet Developer
    #214456
    Hi David,
    There’re some hints for you:
    Remove the code that generates user 7, 8, 9 in the index.php
    Replace it with the code that generates JA Header.
    Of course you need to do some CSS styling too.
    Regards,
    Ha Le-Viet.
    andretti Friend
    #215031
    Thanks for the tip.
    But let’s say I WANT the user modules on the front page and then the JA Header module in the same place for some of the Section pages…
    I realize I can assign different templates to different pages, and this seems to be such a time… but how much of the original template do I have to save under a new name for this to work?
    Do I need to make a new folder and move ALL of the template content into this one, rename it, only to change a few lines in the index.php? It seems pretty redundant. But maybe it’s the only way to go?
    To summarize: If I have a base template that I like, but what to make minor changes under a new template name to be able to assign to different pages… how much needs to be re-saved. And how?
    Many thanks for any input!
    Andrée
    #215041
    Hi Andretti,
    You don’t have to set different templates on different pages or duplicate any files. All you need to do is to put some if…else block with mosCountModules and mosLoadModules function into the index.php file, and then set your module positions to corresponding pages.
    Regards,
    Ha Le-Viet.
    andretti Friend
    #215117
    Hi again!
    Don’t mean to steal too much of your time, but could you give a code example of such a if- else statement?
    I want my user7-9 on my front page and maybe some other pages. But then some pages would look nice with a JA_header script rotating images…
    I don’t really know php, even if that’s obviously going to change with Joomla in my life.
    Thanks,
    A
    p.s. Friend
    #216859
    Hi!
    I really ike this template a lot but can anyone post a idiotproof step by step method to integrate the JA header module with this template. I’d like to know what code is to be swapped in the index.php files! Any help is much apreciated.
    Thanks.
    P.S.
This topic contains 6 replies, has 4 voices, and was last updated by  p.s. 17 years, 9 months ago.
