July 30, 2008 at 8:37 am #131518
There is this great tab module feature shown on the demo of Kulanite.:)
Is there any way to use this module and have it look like it does in Kulanite within the Mesolite template? We want to use the tab module instead of the sliding module in that same position.
We’re using the Joomla 1.5 version of the Mesolite template.
Any help or guidance on if/how we can do this would be greatly appreciated.
The Mesolite and Kulanite templates are super! We had a hard time choosing which one to use and would love to incorporate the best of both worlds if we can.
Menalto FriendMenalto
- May 2007
- 531 times in 361 posts
July 30, 2008 at 9:00 am #263025You can just install the plug in and module for the tabs from Kulanite, and set it up as you wanna have it, there is a few settings in the backend where you can set the theme to use for the tabs, so install it and play around and let us know how it is going?
July 31, 2008 at 9:11 am #263189Hi, Thanks for the info. I was able to download and install the module and plugin but I can’t seem to get the tabs to look right. They overlap terribly. Check it out at http://tdsdevelopment.net/bodydeli/
Here’s what I have entered in parameters in the module:
{jatabs type=”articles” catid=”45″ numberTabs=4 view=”introtext” position=”bottom” widthTabs=150 heightTabs=30 width=”735″ height=”250″ mousetype=”click” animType=”animFade” skipAnim=”false” duration=1000 }{/jatabs}
I’m trying to get this to look like the tabs in the Kulanite Demo. Any ideas on what I could do to make this work right? I really don’t like the way it is looking right now.
Thanks much for any help and assistance.
Nguyen Hong FriendNguyen Hong
- 20 times in 18 posts
August 1, 2008 at 3:28 am #263335Hi sreco,
Please send url and admin account of your site via pm, i will check it for you.Nguyen Hong FriendNguyen Hong
August 3, 2008 at 4:09 pm #263617Hi,
To it works well width , I have added some as below:
– i uninstall JA Tabs module and reinstall new version JA Tabs module
– in manager JA Tabs module -> Advanced Parameters-> i set Module Class Suffix param to “_tabs”
– in template.css file of Mesolite Template, i added:
div.moduletable_tabs {
margin: 0;
padding: 0 15px 10px;
border-bottom: 1px solid #E6E6E6;
Good luck 🙂
August 4, 2008 at 2:56 am #263677Thank you, Thank you, Thank you!
This is great information and the fix you did looks great!!!!!I can’t thank you enough for helping me out with this.
I’ll keep this info on file for sure.
This topic contains 6 replies, has 4 voices, and was last updated by sreco 16 years, 4 months ago.
