  • zendar Friend
    #163773
    i’m new with joomlart templates so i’m a bit “lost” into the features of your great template Teline IV.
    I would like to implement Kunena and JFBConnect, so before loosing mind with mysql and php i would know a couple of things.
    First of all, which is the best sequence on installing them ? Can i go on with Teline and Kunena and upgrade with JFBConnect on later time ?
    Is it possible to have Kunena Menu integrated with Mega Menu? I’ve tried this locally but i couldn’t get it working.
    Thanks a lot in advance.
    If you got the live site, please provide me because i would like to have a look.
    <blockquote>
    </blockquote>
    Kunena forum need mootools 1.2, so you try enabling the Mootools Upgrade Plugin for checking this again
    Ricardo Miura Friend
    #395151
    I have the same problem, my site is online, and i´m trying to instal kunena… it´s possible under tevlineIV ?!?
    amita Friend
    #395230
    Hi ricardomiura
    You can install Kunena under JA Teline IV. JA Teline IV is just a template, it will not stop any extension to work with it. But Kunena menu can not be integrated as such with mega menu , but you can copy the menu item link and use in mega menu as external url.
    #395373
    Amita, I know that, finally I installed the kunena, but for some reason it isnt’t working in my template Teline IV, I tried to work with Menthys and is ok… If you see my sites, it’s possible to you find the problem ?!? It could be a language problem ?!? I have noticed that teline uses /en and menthys dont…. http://www.maisfotografia.com.br and http://www.bikestyle.com.br
    amita Friend
    #395429
    I have worked on both the sites.Your site http://www.bikestyle.com.br has opened but FORUM link give me 500 internal error & another site http://www.maisfotografia.com.br has asked for login username & password. If you can provide joomla admin details & FTP details for both sites at http://support.joomlart.com/index.php?/Tickets/Ticket/View/74219 or you can send via PM, so that it would be great to solve your issue.
    amita Friend
    #395650
    Please provide your joomla admin details & FTP details for http://www.bikestyle.com.br at
    Also , provide login username & password for site http://www.maisfotografia.com.br because that site has asked for login.
    Thank you.
    paulinahi Friend
    #395737
    <em>@ricardomiura 245515 wrote:</em><blockquote>I have the same problem, my site is online, and i´m trying to instal kunena… it´s possible under tevlineIV ?!?</blockquote>
    I have successfully installed Kunena in my TelineIV yesterday. First, I installed Kunena and enabled it in mega menu, when I click on the link in my mega menu I was having 500 internal server error. So I did this:
    Extensions – Module Manager – JA News Sticker Module [open this module and go to Menu Assignment then Module assignment (only on the pages selected) in Kunena Menu (deselect everything) and in Magazine (deselect the title you have given to your Kunena forum) Save & close.
    Next go back to Module Manager and repeat the above to all JA Bulletin there are quite a few JA Bulletin in the Module Manager.
    See Kunena Forum
    I hope this will help
    1. Kunene-Forum
    laciberes Friend
    #404006
    Thanks a lot my friend, I was looking for this answer desperately 😀
This topic contains 9 replies, has 6 voices, and was last updated by  laciberes 13 years, 5 months ago.
