  • softwarekiller Friend
    #175347
    There are some module color variations which are activated through module class suffix (blue, red, green, black, text..). But they only work in the right column. They don’t work neither in the left column nor with the Spotlight user modules. I set the suffix but the color variations doesn’t work. The badges do, however.
    Where can I make it work? I guess somewhere in the template.css but I couldn’t find it.
    Please, help!
    My template is based on Purity II, under J 2.5.
    swissa Friend
    #445461
    If you look in your template.css at around line 133 you will see all the css for the contrast module and then at around 1117 it gives you additional css for the text for the suffix.
    You’d need to add similar css to any of the elements you want styled e.g. div.ja-moduletable
    I’d make a copy of the css file as a backup and then just play with it to be honest! May take a bit of work and testing depending on how many elements you want to style! 😉
    Bestens
    #445468
    I’ve found the answer. It was so easy that I’d rather smashed my head into the wall. I simply added the “jarounded” style to the left and spotlight block in the default layout. It also applies the color suffixes…
This topic contains 3 replies, has 2 voices, and was last updated by  softwarekiller 12 years, 8 months ago.
