  • kmjrecords Friend
    #168331
    Can I use the Blog extension in Ja Blazes on my Ja community Template. if so what is the name of the extension in Blazes
    Manos Moderator
    #411519
    I am not sure if there is a blog extension on JA Blazes …can you please show me (post a link) on which page you are referring ?
    If you are saying about this one – > http://templates.joomlart.com/ja_blazes/index.php?option=com_k2&view=itemlist&layout=category&task=category&id=1&Itemid=54 then it’s just K2 for J1.5.x
    Manos
    kmjrecords Friend
    #411527
    Hey manos
    Yes that is exactly what i am referring too. Is there any pot holes I need to be aware of when trying to use K2 on my site
    Manos Moderator
    #411531
    If you are on j1.5.x then you can install k2 and you will also need the k2 templates overwrites from JA Blaises to make this work.
    Manos
    kmjrecords Friend
    #411546
    I am using 1.7.
    Manos Moderator
    #411559
    Unfortunately as far as i know k2 for j.1.7.x is not yet released so in this case you might have to wait or you can try to customize joomla content blog view in the same way ( i guess you will be helped even more when JA Blaize for j.1.7 will be published for this).
    Manos
This topic contains 6 replies, has 2 voices, and was last updated by  Manos 13 years, 3 months ago.
