  • kcdesi Friend
    #192573
    See the URL – http://www.kcdesi.com/k25/index.php/entertainment-link/kcdesi-movie-reviews
    The five sections at the top is the JA_newspro module. I am using 0 intro articles, and only want links to be displayed here. However I also don’t want the ‘More’ link at the top and the space above that.
    Where do I change that? I looked through obvious locations but didn’t find anything so far.
    Hi kcdesi,
    If you don’t want to show ‘More’ links, try going to Profile settings and set 0 to Link Items.
    For the space, pls send me screenshot of how you want to achieve, I will give better suggestion (also set Optimize CSS in template manager to No).
    kcdesi Friend
    #514365
    I have attached a snapshot.
    1. I want to be able to style the title here – e.g. caps, smaller font, etc.
    2. I want to be able to style the text itself.
    3. There is a space between the ‘Announcements’ and ‘More’ – want to remove or reduce it.
    4. I want to change the text ‘More’ to something else e.g., ‘Click for more stories from this category’ – again styled.
    What can be done? I scoured the module directory and the css of the template itself with not much of a progress.
    Thank you for all your help.
    Link: http://www.kcdesi.com/k25/kcdesi-local-links/kcdesi-videos
    and Optimize CSS is off till you confirm.
    1. Capture
    TomC Moderator
    #514369
    <em>@kcdesi 400599 wrote:</em><blockquote>
    1. I want to be able to style the title here – e.g. caps, smaller font, etc.</blockquote>
    To style the titles/headings for your articles, look to the following file path –>
    /k25/templates/ja_nex/css/template.css
    starting at line 27, you will see the following . . .
    a {
    color: #666666
    text-decoration: none;
    a:hover, a:active, a:focus {
    color: #CC3333
    This is where you can modify and add additional properties to style your heading any way you like
    – such as “font-size,” “font-color,” “font-weight,” etc.
    Look to file path –> /k25/templates/ja_nex/css/template.css
    at line 25 – like above – you can modify or add whatever properties you want to style the text, for example . . .
    a {
    color: #666666
    font-size: 15px;
    Look to file path –> /k25/modules/mod_janewspro/tmpl/default/style.css
    at line 18, you will see the following . . .
    .default .ja-zin .ja-box .ja-box-inner {
    margin: 0;
    padding: 8px 12px 5px;
    To reduce the space as you indicated, you can modify the padding property such as . . .
    margin: 0;
    padding: 1px 12px 5px;
    Hope That Helps a bit.
    kcdesi Friend
    #514395
    That helped a lot!! Thank you very much Tom.
    TomC Moderator
    #514399
    <em>@kcdesi 400639 wrote:</em><blockquote>That helped a lot!! Thank you very much Tom.</blockquote>
    Glad to be of assistance . . . All the best with your continuing site development.
This topic contains 6 replies, has 3 voices, and was last updated by  TomC 11 years, 1 month ago.
