February 27, 2013 at 2:34 pm #185368
Hi there,
I want to use a module in “position=right” next to the “Fashion & Shopping” section, however I don’t want that column extending all the way down the page, I want the main content section to be full width. I’ve attached a diagram of what I’m hoping to achieve.
Is this something that can be achieved in the backend, or do I have to delve into setting DIV heights in CSS? Thanks in advance
February 28, 2013 at 4:53 am #484841Hi clarkeimages,
The default layout of this template is ‘main-left-right’, in order to achieve that, you can hide module in left and right position, the main content will expand automatically.
The “Fashion & Shopping” section belongs to content-mass-top position, you can assign any module to this position if you want.
This wiki guide will help you know more about our framework’s layout: http://wiki.joomlart.com/wiki/JA_T3_Framework_2/Guides#Layouts
February 28, 2013 at 7:35 pm #484938<em>@Saguaros 362196 wrote:</em><blockquote>Hi clarkeimages,
Regards</blockquote>
Hi Saguaros,
I’ve got stuff in content-mass-top, and I want to put content next to it in right, however the content that I want to put there isn’t very long, so I’ve got a mostly empty column extending down my page. I looked at that link you gave me, and tried to understand it… I played with content-mass-bottom and content-mass-right but I’m getting the same thing a long column that is cutting off my main K2 content. I’ve attached 2 very artistic renderings of what I am trying to achieve, vs what my end result is.
March 1, 2013 at 3:15 am #484963Hi,
You can try this way:
– Unpublish all module in left and right position, then the main content will have width of 100%
– Above the main content, you can assign module in positions: user1, user2, … (this layout has user1, user2, user3, user4, user5 positions)
Here is the result when I test in my local: http://i.imgur.com/1yZQv2P.jpg
You can make some change in css a little bit to achieve as you desired.
March 1, 2013 at 4:34 pm #485042Hi Saguaros,
That worked, but it was splitting the top 50/50 so I copied the specialwidth=”30″ from the bottom spotlight line and I’ve got it laid out perfectly. Thanks!
Viewing 6 posts - 1 through 6 (of 6 total)This topic contains 6 replies, has 2 voices, and was last updated by Saguaros 11 years, 9 months ago.
