  • raholt Friend
    #937678
    Re: JA Onepage template – Metro Theme.
    See Screenshot: http://screencast.com/t/dhyzDmdMON
    1. I am using the "Metro" theme in Ja Onepage. How can I simply use the "block with text" for the titles in each section from the Modern Style to "Metro" style?
    2. I like the font used in "Modern" but like the layout of "Metro." So how do I change it in "Metro" to use blocks for titles and use the font?
    Thank you,
    Ron Holt
    Pankaj Sharma Moderator
    #937744
    Each template theme have different kind of style used as per their design concept . In case u want to copy a style from different theme , you can check the style code using inspect element from browser : http://prntscr.com/bcabc2
    and add the style in custom.css file to apply it on your style : http://prntscr.com/bcaby1
    this way you achieve this customization in style .
This topic contains 1 reply, has 2 voices, and was last updated by  Pankaj Sharma 8 years, 5 months ago.
