Khanh Le Moderator
Khanh Le
- November 2013
- 203 times in 131 posts
August 7, 2010 at 3:37 am #153208Case: Your site install both extensions: T3v2 & Advanced Module Manager.
Problem: Both extensions override core joomla JModuleHelper class.
Solution: Merge 2 override into one class.
I have merged our override part to the class of AMM and attach to this thread. Follow these steps to update your current site.
1. Download the attachment, copy overwrite file plugins/system/advancedmodules/modulehelper.php.
2. Open for edit file plugins/system/jat3/core/framework.php, line 25:
To:
if (!class_exists ('JModuleHelper')) t3import ('core.joomla.modulehelper');
Update 1: Add checking to ignore override for T3 in modulehelper when in administrator (thank galwen).
October 2, 2010 at 10:25 am #357456I had spent months in frustration trying to get T3 to work like in the guides…and blank!
Then I found a thread that mentioned that Advanced Module Manager and T3 don’t go together – I tested it out by disabling AMM and found that T3 now worked fine. However, was devastated as I rely heavily on AMM and need BOTH!Am so glad to have found this solution – it works great!
Thank you khanh le!I don’t quite understand this line, though:
<blockquote>Update 1: Add checking to ignore override for T3 in modulehelper when in administrator</blockquote>Is this already in the solved code or does anything more need to be added?
Khanh Le Moderator
Khanh Le
- November 2013
October 2, 2010 at 10:32 am #357457<em>@equest 196526 wrote:</em><blockquote>
Is this already in the solved code or does anything more need to be added?</blockquote>
Already in the solved code.October 2, 2010 at 11:50 am #357468Thank you! 😀
socoweb Friend
socoweb
- April 2008
- 5 times in 1 posts
October 12, 2010 at 7:31 pm #358658it’s not always line 25.
If you update with the NoNumber Extension Manager, you will need to update the moduleshelper.php file again!
November 11, 2010 at 1:37 pm #362453Thanks, that fixed my problem:laugh:
socoweb Friend
socoweb
- April 2008
November 11, 2010 at 2:29 pm #362457NoNumber has updated the Advanced Module Manager to be compatible with the T3 framework! Thank you Peter!
http://www.nonumber.nl/extensions/advancedmodulemanager
Now only the plugins/system/jat3/core/framework.php file needs updated
Arvind Chauhan Moderator
Arvind Chauhan
- 1334 times in 848 posts
November 11, 2010 at 5:18 pm #362476Guys,
Its fixed now. T3 plugin 1.2.0 is out. Peter, Stephen and we worked together to solve the issue and they would also be releasing their versions soon.
thatch10 Friend
thatch10
- May 2008
- 19 times in 1 posts
November 14, 2010 at 12:25 pm #362831Using JA T3 Plugin 1.2.0 and Advanced Module Manager 1.13.0 on 2 sites
both are now giving the warning – Warning: Missing argument 2 for plgSystemJAT3::onRenderModule() in user/htdocs/plugins/system/jat3.php on line 191
Reverting Back to modified JA T3 Plugin 1.1.8 removes the warning.
Khanh Le Moderator
Khanh Le
- November 2013
November 15, 2010 at 2:34 am #362865T3 Plugin & Advanced Module Manager both override the core Joomla modulehelper class and cause conflict. We recently work together to resolve this issue. The fix is updated into our latest release for T3 (1.2.0) and will be available in coming update of AMM (v 1.13.1).
At this time, you can copy file modulehelper.php for T3 v1.2.0 (plugins/system/jat3/core/joomla/modulehelper.php) and override the file in AMM (plugins/system/advancedmodules/modulehelper.php) to solve the problem.
1 user says Thank You to Khanh Le for this useful post
November 15, 2010 at 5:58 am #362878<em>@thatch10 203505 wrote:</em><blockquote>Using JA T3 Plugin 1.2.0 and Advanced Module Manager 1.13.0 on 2 sites
Reverting Back to modified JA T3 Plugin 1.1.8 removes the warning.</blockquote>
Hi. Open the file user/htdocs/plugins/system/jat3.php and at line 191 add the red text:
function onRenderModule (&$module, $attribs = array()) {
Now works! 🙂
November 18, 2010 at 7:15 pm #363314<em>@elvisvinicius 203582 wrote:</em><blockquote>Hi. Open the file user/htdocs/plugins/system/jat3.php and at line 191 add the red text:
Now works! 🙂
(^ ^)</blockquote>
Thanks Elvisvinicius! :laugh:
January 14, 2011 at 7:11 pm #371890Did You know somethink about using T3 Framework 2 with Panel Sharing?
You can see that on my site : http://zarabiaczek.pl clicking on any article . Plugin is on but it cant load on page with my articles or content :/
I Cant fix it alone 🙁February 7, 2011 at 12:02 pm #375381Just if someone should happen to run in the same problem – I installed a T3 Framework based template and installed joomfish and eventually the Advanced Module Manager (AMM). Since the main page wouldn’t load afterwards anymore (error: 500 – no valid db connection) I assumed it would be related to problems with T3 and AMM – however you only need to disable the System – Jfdatabase plugin and enable it afterwards again. Since Joomfish seems a rather popular extension I thought it would be worth mentioning here.
midsomer Friend
midsomer
- February 2010
February 8, 2011 at 3:38 pm #375661I had this similar issue when I installed JA Social template and the required JAT3 plugin from the latest download.
Using J1.5.22 , JA Social v1.2.1, JAT3 v1.2.3, AMM v1.9.7I got a list of warnings in the backend and frontend <blockquote>Warning: Missing argument 2 for plgSystemJAT3::onRenderModule() in user/htdocs/plugins/system/jat3.php on line 214</blockquote>
It took a few hours to find this possible fix, which I’m pleased to report did fix it.
<em>@khanh le 203566 wrote:</em><blockquote>T3 Plugin & Advanced Module Manager both override the core Joomla modulehelper class and cause conflict. We recently work together to resolve this issue. The fix is updated into our latest release for T3 (1.2.0) and will be available in coming update of AMM (v 1.13.1).
At this time, you can copy file modulehelper.php for T3 v1.2.0 (plugins/system/jat3/core/joomla/modulehelper.php) and override the file in AMM (plugins/system/advancedmodules/modulehelper.php) to solve the problem.</blockquote>
Replaced the modulehelper.php in the AMM with a copy from JAT3 and it cleared the warnings.
Hoping to see this fixed in AMM upgrades.
This topic contains 34 replies, has 23 voices, and was last updated by Blaine 12 years, 9 months ago.
