February 16, 2011 at 7:53 pm #377015
Thank you! :laugh:
June 29, 2011 at 5:30 pm #399166hello
Joomla 1.6.3
T3 PLUGIN 1.2.7
modules anywhere – 1.11.3
Problem – Class ‘T3Path’ not found in /var/www/v002162/data/www/ddddddddd.com/plugins/system/jat3/jat3/core/common.php on line 52
Can We help me plzz??BigHug Friend
BigHug
- September 2012
- 11 times in 1 posts
July 5, 2011 at 2:48 am #399853Hi feaire
First you need to update T3 plugin. If it isn’t fixed, you could PM me with your admin & ftp account then I shall check for you.
Niccolo Villiger Friend
Niccolo Villiger
July 14, 2011 at 4:49 pm #401191hi,
i have same issue
joomla 1.6.5, jat3 1.2.8 and modulesanywhere 1.11.3Thanks in advance
anoush<em>@dohq 251444 wrote:</em><blockquote>Hi feaire
First you need to update T3 plugin. If it isn’t fixed, you could PM me with your admin & ftp account then I shall check for you.</blockquote>
Niccolo Villiger
July 14, 2011 at 5:13 pm #401193i “solved” with this other plugin
http://extensions.joomla.org/extensions/core-enhancements/embed-a-include/6958<em>@webmarketingteam 253193 wrote:</em><blockquote>hi,
i have same issue
anoush</blockquote>July 19, 2011 at 9:32 am #401828I have the exact same problem i get when i try to insert an article into a module using articles anywhere plugin
Fatal error: Class ‘T3Path’ not found in /home7/newbree1/public_html/hollywoodfurnishing/plugins/system/jat3/jat3/core/common.php on line 52
Thanks in advance
pritam Friend
pritam
- April 2011
- 125 times in 113 posts
July 20, 2011 at 6:48 am #402002Hello boast32 ,
To solve the issue Class ‘T3Path’ not found
You can goto yourdomain/plugins/system/jat3.php
Find this code :-
function onRenderModule (&$module, $attribs){
Change this code to :-
function onRenderModule (&$module, $attribs = array()) {
You can also refer to this url :-
http://www.joomlart.com/forums/topic/using-t3v2-with-advanced-module-manager/#post-399166
July 27, 2011 at 7:17 pm #403347Hello!!
I have the same problem but the tips dont work for me!!
anyone can help me plz???
August 2, 2011 at 2:31 pm #404190Hi, I have the same problem on
Joomla 1.7
Modules Anywhere 1.11.5And I had it before on Joomla 1.6 as well using Ja Purity template.
The module (Modules Anywhere) does not work inside another module, it only shows the name of the module, not the content.
It worked though in some articles.Any advise,
-AnnaAugust 2, 2011 at 2:36 pm #404192hello,
you have the fatal error with the line 52 on it ??
if so maybe try to add this :
<blockquote>t3import(‘core.path’);</blockquote>
just before the line 52
For me it worked but i dont think we got the exact same problem 😀
1 user says Thank You to keinsei for this useful post
August 2, 2011 at 2:50 pm #404194No, it did not work for me. I don’t an error displaying, it just doesn’t display the full module, just the title of the module.
Thanks!<em>@keinsei 257145 wrote:</em><blockquote>hello,
For me it worked but i dont think we got the exact same problem :D</blockquote>
pritam Friend
pritam
- April 2011
August 3, 2011 at 7:42 am #404294Hello ,
Open this file : pluginssystemjat3jat3corejoomlamodulehelper.php
Find this code $query = new JDatabaseQuery
Replace to :- $query = $db->getQuery(true);
You can also refer to this :-
http://groups.google.com/group/joomla-dev-general/browse_thread/thread/5f18d884338e647a?pli=1August 11, 2011 at 8:51 pm #405777<em>@pritam 257283 wrote:</em><blockquote>Hello ,
http://groups.google.com/group/joomla-dev-general/browse_thread/thread/5f18d884338e647a?pli=1</blockquote>No, this code is fixed, but I still watch the fatal error… (J1.7, T3 1.2.2, Articles Anywhere 1.11.7)
pritam Friend
pritam
- April 2011
August 12, 2011 at 6:00 am #405834<em>@boast32 254027 wrote:</em><blockquote>I have the exact same problem i get when i try to insert an article into a module using articles anywhere plugin
Thanks in advance</blockquote>
Hello boast32 ,
You can refer to this url :-
http://www.joomlart.com/forums/showthread.php?60127-Fatal-error-Class-T3Path
August 12, 2011 at 6:23 am #405839<em>@keinsei 257145 wrote:</em><blockquote>hello,
It works!! (J1.7, T3 1.3.0 Beta, Articles Anywhere 1.11.7)
This topic contains 34 replies, has 23 voices, and was last updated by Blaine 12 years, 9 months ago.
