August 26, 2011 at 3:35 am #408624
Please, update de thread for the version 2.0.2 of component AMM:
The original source (no changes):
<?php
* @package Advanced Module Manager
* @version 2.0.2
* @authors Stephen Brandon <stephen@brandonitconsulting.co.uk>
* Peter van Westen <peter@nonumber.nl>
* Khanh Le Huy <khanhlh@joomsolutions.com>
* @copyright Copyright (C) 2011 - All Rights Reserved
* Brandon IT Consulting (http://www.metamodpro.com)
* NoNumber! (http://www.nonumber.nl)
* JoomlArt (http://www.joomlart.com)
* @license http://www.gnu.org/licenses/gpl-2.0.html GNU/GPL
* BASE ON JOOMLA CORE FILE:
* /libraries/joomla/application/module/helper.php
* @package Joomla.Platform
* @subpackage Application
* @copyright Copyright (C) 2005 - 2011 Open Source Matters, Inc. All rights reserved.
* @license GNU General Public License version 2 or later; see LICENSE
*/// No direct access
defined('JPATH_PLATFORM') or defined('JPATH_BASE') or die;// Import library dependencies
jimport('joomla.application.component.helper');/**
* Module helper class
* @since 11.1
abstract class JModuleHelper
* Get module by name (real, eg 'Breadcrumbs' or folder, eg 'mod_breadcrumbs')
* @param string $name The name of the module
* @param string $title The title of the module, optional
* @return object The Module object
* @since 11.1
public static function &getModule($name, $title = null)
$result = null;
$modules = JModuleHelper::_load();
$total = count($modules);for ($i = 0; $i < $total; $i++)
// Match the name of the module
if ($modules[$i]->name == $name || $modules[$i]->module == $name) {
// Match the title if we're looking for a specific instance of the module
if (!$title || $modules[$i]->title == $title) {
// Found it
$result = &$modules[$i];
break; // Found it
}// If we didn't find it, and the name is mod_something, create a dummy object
if (is_null($result) && substr($name, 0, 4) == 'mod_') {
$result = new stdClass;
$result->id = 0;
$result->title = '';
$result->module = $name;
$result->position = '';
$result->content = '';
$result->showtitle = 0;
$result->control = '';
$result->params = '';
$result->user = 0;
}return $result;
* Get modules by position
* @param string $position The position of the module
* @return array An array of module objects
* @since 11.1
public static function &getModules($position)
$app = JFactory::getApplication();
$position = strtolower($position);
$result = array();$modules = JModuleHelper::_load();
if ($modules[$i]->position == $position) {
$result[] = &$modules[$i];
}if (count($result) == 0) {
if (JRequest::getBool('tp') && JComponentHelper::getParams('com_templates')->get('template_positions_display')) {
$result[0] = JModuleHelper::getModule('mod_'.$position);
$result[0]->title = $position;
$result[0]->content = $position;
$result[0]->position = $position;
}return $result;
* Checks if a module is enabled
* @param string $module The module name
* @return boolean
* @since 11.1
public static function isEnabled($module)
$result = JModuleHelper::getModule($module);return !is_null($result);
* Render the module.
* @param object $module A module object.
* @param array $attribs An array of attributes for the module (probably from the XML).
* @return string The HTML content of the module output.
* @since 11.1
public static function renderModule($module, $attribs = array())
static $chrome;if (constant('JDEBUG')) {
JProfiler::getInstance('Application')->mark('beforeRenderModule '.$module->module.' ('.$module->title.')');
}$option = JRequest::getCmd('option');
$app = JFactory::getApplication();// Record the scope.
$scope = $app->scope;// Set scope to component name
$app->scope = $module->module;// Get module parameters
$params = new JRegistry;
$params->loadString($module->params);// Get module path
$module->module = preg_replace('/[^A-Z0-9_.-]/i', '', $module->module);
$path = JPATH_BASE.'/modules/'.$module->module.'/'.$module->module.'.php';// Load the module
if (!$module->user && file_exists($path)) {
$lang = JFactory::getLanguage();
// 1.5 or Core then 1.6 3PD
$lang->load($module->module, JPATH_BASE, null, false, false)
|| $lang->load($module->module, dirname($path), null, false, false)
|| $lang->load($module->module, JPATH_BASE, $lang->getDefault(), false, false)
|| $lang->load($module->module, dirname($path), $lang->getDefault(), false, false);$content = '';
ob_start();
require $path;
$module->content = ob_get_contents().$content;
ob_end_clean();
}// Load the module chrome functions
if (!$chrome) {
$chrome = array();
}require_once JPATH_THEMES.'/system/html/modules.php';
$chromePath = JPATH_THEMES.'/'.$app->getTemplate().'/html/modules.php';if (!isset($chrome[$chromePath])) {
if (file_exists($chromePath)) {
require_once $chromePath;
}$chrome[$chromePath] = true;
}// Make sure a style is set
if (!isset($attribs['style'])) {
$attribs['style'] = 'none';
}// Dynamically add outline style
$attribs['style'] .= ' outline';
}// Do 3rd party stuff to manipulate module content
// onRenderModule is allowed to alter the $module, $attribs
// and may return a boolean.
// true=remove, any other value = keep.
// $result holds an array of booleans, 1 from each plugin.
// we ditch the module if any of them = true.
$result = $app->triggerEvent( 'onRenderModule', array( &$module, &$attribs ) );
if ( array_search( true, $result, true ) !== false ) {
return '';
}foreach(explode(' ', $attribs['style']) as $style)
$chromeMethod = 'modChrome_'.$style;// Apply chrome and render module
if (function_exists($chromeMethod)) {
$module->style = $attribs['style'];ob_start();
$chromeMethod($module, $params, $attribs);
$module->content = ob_get_contents();
ob_end_clean();
}//revert the scope
$app->scope = $scope;if (constant('JDEBUG')) {
JProfiler::getInstance('Application')->mark('afterRenderModule '.$module->module.' ('.$module->title.')');
}return $module->content;
* Get the path to a layout for a module
* @param string $module The name of the module
* @param string $layout The name of the module layout. If alternative
* layout, in the form template:filename.
* @return string The path to the module layout
* @since 11.1
public static function getLayoutPath($module, $layout = 'default')
$template = JFactory::getApplication()->getTemplate();
$defaultLayout = $layout;if (strpos($layout, ':') !== false ) {
// Get the template and file name from the string
$temp = explode(':', $layout);
$template = ($temp[0] == '_') ? $template : $temp[0];
$layout = $temp[1];
$defaultLayout = ($temp[1]) ? $temp[1] : 'default';
}// Build the template and base path for the layout
$tPath = JPATH_THEMES.'/'.$template.'/html/'.$module.'/'.$layout.'.php';
$bPath = JPATH_BASE.'/modules/'.$module.'/tmpl/'.$defaultLayout.'.php';// Do 3rd party stuff to detect layout path for the module
// onGetLayoutPath should return the path to the $layout of $module or false
// $results holds an array of results returned from plugins, 1 from each plugin.
// if a path to the $layout is found and it is a file, return that path
$result = $app->triggerEvent( 'onGetLayoutPath', array( $module, $layout ) );
if (is_array($result)) {
foreach ($result as $path) {
if ($path !== false && is_file ($path)) return $path;
}// If the template has a layout override use it
if (file_exists($tPath)) {
return $tPath;
else {
return $bPath;
* Load published modules.
* @return array
* @since 11.1
protected static function &_load()
static $clean;if (isset($clean)) {
return $clean;
}$Itemid = JRequest::getInt('Itemid');
$user = JFactory::getUser();
$groups = implode(',', $user->getAuthorisedViewLevels());
$lang = JFactory::getLanguage()->getTag();
$clientId = (int) $app->getClientId();/*
$cache = JFactory::getCache ('com_modules', '');
$cacheid = md5(serialize(array($Itemid, $groups, $clientId, $lang)));if (!($clean = $cache->get($cacheid))) {
$db = JFactory::getDbo();$query = new stdClass();
$query->select = array();
$query->from = array();
$query->join = array();
$query->where = array();
$query->order = array();$query->select[] = 'm.published, m.id, m.title, m.module, m.position, m.content, m.showtitle, m.params, mm.menuid';
$query->from[] = '#__modules AS m';
$query->join[] = '#__modules_menu AS mm ON mm.moduleid = m.id';
$query->where[] = 'm.published = 1';$query->join[] = '#__extensions AS e ON e.element = m.module AND e.client_id = m.client_id';
$query->where[] = 'e.enabled = 1';$date = JFactory::getDate();
$now = $date->toMySQL();
$nullDate = $db->getNullDate();
$query->where[] = '(m.publish_up = '.$db->Quote($nullDate).' OR m.publish_up <= '.$db->Quote($now).')';
$query->where[] = '(m.publish_down = '.$db->Quote($nullDate).' OR m.publish_down >= '.$db->Quote($now).')';$query->where[] = 'm.access IN ('.$groups.')';
$query->where[] = 'm.client_id = '. $clientId;
$query->where[] = '(mm.menuid = '. (int) $Itemid .' OR mm.menuid <= 0)';// Filter by language
if ($app->isSite() && $app->getLanguageFilter()) {
$query->where[] = 'm.language IN (' . $db->Quote($lang) . ',' . $db->Quote('*') . ')';
}$query->order[] = 'm.position, m.ordering';
// Do 3rd party stuff to change query
$app->triggerEvent( 'onCreateModuleQuery', array( &$query ) );$q = $db->getQuery(true);
// convert array object to query object
foreach ( $query as $type => $strings ) {
foreach ( $strings as $string ) {
if ( $type == 'join' ) {
$q->{$type}( 'LEFT', $string );
} else {
$q->{$type}( $string );
}// Set the query
$db->setQuery($q);
$modules = $db->loadObjectList();
$clean = array();if ($db->getErrorNum()){
JError::raiseWarning(500, JText::sprintf('JLIB_APPLICATION_ERROR_MODULE_LOAD', $db->getErrorMsg()));
return $clean;
}// Apply negative selections and eliminate duplicates
$negId = $Itemid ? -(int)$Itemid : false;
$dupes = array();
for ($i = 0, $n = count($modules); $i < $n; $i++)
$module = &$modules[$i];// The module is excluded if there is an explicit prohibition or if
// the Itemid is missing or zero and the module is in exclude mode.
$negHit = ($negId === (int) $module->menuid)
|| (!$negId && (int)$module->menuid < 0);if (isset($dupes[$module->id])) {
// If this item has been excluded, keep the duplicate flag set,
// but remove any item from the cleaned array.
if ($negHit) {
unset($clean[$module->id]);
continue;
}$dupes[$module->id] = true;
// Only accept modules without explicit exclusions.
if (!$negHit) {
//determine if this is a custom module
$file = $module->module;
$custom = substr($file, 0, 4) == 'mod_' ? 0 : 1;
$module->user = $custom;
// Custom module name is given by the title field, otherwise strip off "mod_"
$module->name = $custom ? $module->title : substr($file, 4);
$module->style = null;
$module->position = strtolower($module->position);
$clean[$module->id] = $module;
}unset($dupes);
// Do 3rd party stuff to manipulate module array.
// Any plugins using this architecture may make alterations to the referenced $modules array.
// To remove items you can do unset($modules[n]) or $modules[n]->published = false.// "onPrepareModuleList" may alter or add $modules, and does not need to return anything.
// This should be used for module addition/deletion that the user would expect to happen at an
// early stage.
$app->triggerEvent( 'onPrepareModuleList', array( &$clean ) );// "onAlterModuleList" may alter or add $modules, and does not need to return anything.
$app->triggerEvent( 'onAlterModuleList', array( &$clean ) );// "onPostProcessModuleList" allows a plugin to perform actions like parameter changes
// on the completed list of modules and is guaranteed to occur *after*
// the earlier plugins.
$app->triggerEvent( 'onPostProcessModuleList', array( &$clean ) );// Remove any that were marked as disabled during the preceding steps
foreach ( $clean as $id => $module ) {
if ( !isset( $module->published ) || $module->published == 0 ) {
unset( $clean[$id] );
}// Return to simple indexing that matches the query order.
$clean = array_values($clean);/*
$cache->store($clean, $cacheid);
*/return $clean;
* Module cache helper
* Caching modes:
* To be set in XML:
* 'static' One cache file for all pages with the same module parameters
* 'oldstatic' 1.5 definition of module caching, one cache file for all pages
* with the same module id and user aid,
* 'itemid' Changes on itemid change, to be called from inside the module:
* 'safeuri' Id created from $cacheparams->modeparams array,
* 'id' Module sets own cache id's
* @param object $module Module object
* @param object $moduleparams Module parameters
* @param object $cacheparams Module cache parameters - id or url parameters, depending on the module cache mode
* @param array $params Parameters for given mode - calculated id or an array of safe url parameters and their
* variable types, for valid values see {@link JFilterInput::clean()}.
* @return string
* @since 11.1
* @link JFilterInput::clean()
public static function moduleCache($module, $moduleparams, $cacheparams)
if (!isset ($cacheparams->modeparams)) {
$cacheparams->modeparams = null;
}if (!isset ($cacheparams->cachegroup)) {
$cacheparams->cachegroup = $module->module;
}$user = JFactory::getUser();
$cache = JFactory::getCache($cacheparams->cachegroup, 'callback');
$conf = JFactory::getConfig();// Turn cache off for internal callers if parameters are set to off and for all logged in users
if ($moduleparams->get('owncache', null) === 0 || $conf->get('caching') == 0 || $user->get('id')) {
$cache->setCaching(false);
}$cache->setLifeTime($moduleparams->get('cache_time', $conf->get('cachetime') * 60));
$wrkaroundoptions = array (
'nopathway' => 1,
'nohead' => 0,
'nomodules' => 1,
'modulemode' => 1,
'mergehead' => 1
);$wrkarounds = true;
$view_levels = md5(serialize ($user->getAuthorisedViewLevels()));switch ($cacheparams->cachemode) {
case 'id':
$ret = $cache->get(array($cacheparams->class, $cacheparams->method), $cacheparams->methodparams, $cacheparams->modeparams, $wrkarounds, $wrkaroundoptions);
break;case 'safeuri':
$secureid=null;
if (is_array($cacheparams->modeparams)) {
$uri = JRequest::get();
$safeuri = new stdClass();
foreach ($cacheparams->modeparams AS $key => $value) {
// Use int filter for id/catid to clean out spamy slugs
if (isset($uri[$key])) {
$safeuri->$key = JRequest::_cleanVar($uri[$key], 0,$value);
$secureid = md5(serialize(array($safeuri, $cacheparams->method, $moduleparams)));
$ret = $cache->get(array($cacheparams->class, $cacheparams->method), $cacheparams->methodparams, $module->id. $view_levels.$secureid, $wrkarounds, $wrkaroundoptions);
break;case 'static':
$ret = $cache->get(array($cacheparams->class, $cacheparams->method), $cacheparams->methodparams, $module->module.md5(serialize($cacheparams->methodparams)), $wrkarounds, $wrkaroundoptions);
break;case 'oldstatic': // provided for backward compatibility, not really usefull
$ret = $cache->get(array($cacheparams->class, $cacheparams->method), $cacheparams->methodparams, $module->id. $view_levels, $wrkarounds, $wrkaroundoptions);
break;case 'itemid':
default:
$ret = $cache->get(array($cacheparams->class, $cacheparams->method), $cacheparams->methodparams, $module->id. $view_levels.JRequest::getVar('Itemid',null,'default','INT'), $wrkarounds, $wrkaroundoptions);
break;
}return $ret;
}Please, update him for me, thanks.
Blaine FriendBlaine
- August 2007
- 177 times in 154 posts
September 13, 2011 at 3:44 pm #412407Hi adelimateusdmx,
I am not understanding what you need done here. Please clarify for me.
Thanks!tonyzee Friendtonyzee
- November 2011
May 10, 2012 at 6:00 am #452335Hi guys,
I’m using Joomla 2.5.4 with Joomlart JA Social 2.5.1 and Advanced Modules Manager Pro v 3.1.2
My problem is that the module assignments for the ‘components’ assignment selection and also ‘mirror module’ selection are not being respected.
If I select to display a module on a specific component then it just shows on all pages. The only way I can get it to work is to assign the module to each specific menu item (i.e. use joomla standard assignment functionality).
Please can someone let me know if this proposed resolution is still valid and if this will solve my problems?
I’ve posted on the nonumbers forum and peter says the problem is with Joomlart.
Any help is greatly appreciated.
Thanks and regards.
This topic contains 34 replies, has 23 voices, and was last updated by Blaine 12 years, 7 months ago.
