  • neupromo Friend
    #1038018
    Hi there
    I have never had any problems using two templates. It was always easy assigning two Templates to ONE Website.
    "First Template with a Star Symbol". Is set to default.
    Second Template is featured and only the landing page and assigned to template two.
    Ride now it seems the default templates must be asigned to all pages not accepting a landing or future page.
    this is strange, or am I doing something wrong here_
    Screenshot> http://prntscr.com/fdpuff
    http://prntscr.com/fdpuqm
    Thank you
    I’m not entirely sure of issue here, if you set a template is default. Any menu item page which is not assigned to any other template will be automatically assigned to ‘Default’ template.
    You can share the login info here and details the issue on your site so I will take a look.
    neupromo Friend
    #1038395
    Thank you,
    I understand. In may case, I have assigned One Page from my Site to the Second Template. The first Template is set to default. I understand all other pages will be assigned automaticaley to the First Template exept that just one page. I have assigend one page for a landing page to the second template.
    But it seems it is not working.
    http://prntscr.com/fe5sa0
    You can share the credentials of your site and clarify how you want to achieve, I will check for you.
This topic contains 3 replies, has 2 voices, and was last updated by  Saguaros 7 years, 6 months ago.
