  • spelanikita Friend
    #136984
    Hello!
    I have a problem with this site not displaying correctly in ie6. The first page displays as it should but when you click on any of the menu items it dipslays only header.
    Each time you referesh the page using F5 command the page displays as it should.
    The page works normally in FF.
    In safari it doesn’t display right charset..
    I have done about 3 days of research on this matter including SQL Collations, ading php scripts to index file etc.
    Nothing seems to be working..
    The site is online and this account hosts two other live sites so i would apprecitae extra care on dealing with the files and data provided.
    Please help as soon as you can. Thanks!
    scotty Friend
    #285917
    The demo site displays perfect in IE6. Do you have a live URL to your site please?
    spelanikita Friend
    #285919
    all subpages don’t work, the first page works fine:
    http://www.triglif.si
    scotty Friend
    #285921
    Have you been copy&pasting your article content from Microsoft Word?
    spelanikita Friend
    #285925
    i haven’t. but i have copied som content from another site.
    scotty Friend
    #285940
    Can you create a new menu item and a new article with no formatting in the article. Just type in a few sentences.
    Then test to see if this page loads correct. I think you may be suffering from the HTML used to construct your articles.
    spelanikita Friend
    #285945
    You are right. If i dont include “<meta http-equiv=”Content-Type” content=”text/html; charset=UTF-8″ />” in my articles it loads the pages
    BUT
    then it replaces all the characters č,ž,š,Č,Ž,Š with Ž’, ‘ž’, ‘Å¡’, ‘Å’, ‘ÄŒ’, ‘Ä. The page is not useful in any of the browsers then…
    Any ideas?
    Thank you for all your help!!!
    spelanikita Friend
    #285948
    I even tried inserting this code to index.php file:
    <?php function convert($data, $table) {
    $do_update = false;
    foreach($data as $k => $value) {
    if (!is_array($value)) {
    $count = 0;
    $data[$k] = str_replace(array(‘Ž’, ‘ž’, ‘Å¡’, ‘Å’, ‘ÄŒ’, ‘Ä’), array(‘Ž’, ‘ž’, ‘š’, ‘Š’, ‘Č’, ‘č’), $data[$k], $count);
    if ($count> 0) {
    $do_update = true;
    if ($do_update === true) {
    $query = createGenericUpdateSQL($data, $table, key($data), $data[key($data)]);
    dump($query);
    scotty Friend
    #285949
    spelanikita;105452
    This line is missing from your <head>…
    <meta http-equiv=”Content-Type” content=”text/html; charset=utf-8″ />Did you remove it earlier?
    To add it again go to Extensions>templates>Mesolite> at the top you will see ‘Edit HTML’.
    Add the line above immediately AFTER the <head> tag.
    You will also need to go through all your existing articles and remove the unnecessary HTML.
    spelanikita Friend
    #285953
    Scotty thank you sooo much!
    I knew it had to be something simple!
    THANKS; THANKS; THANKS!!!!!
    scotty Friend
    #285955
    You are welcome and I’m glad you got it sorted.
    spelanikita Friend
    #285971
    had to thank you again. this was real important for me to get this solved by tomorow.!!
    Keep up the good work guys. I’ll be a member for a long time ;):)
This topic contains 12 replies, has 2 voices, and was last updated by  spelanikita 15 years, 11 months ago.
