  • ljanak Friend
    #127020
    Hallo,
    can please someone help me? I have this amazing template (dravity), but I still have code problem. I am from slovakia, and I am using UTF-8 code and slovakian texts. How I can pls set up template for good coding? thank you.
    I have this problem with this template only , ussualy in IE7 (sometime is everything ok in firefox). with another template is everithing ok.
    Martin
    Nam Nguyen Phi Friend
    #243708
    To set Charset = utf-8 as default, please open templates/ja_dravity/index.php and add this code
    <meta http-equiv="Content-Type" content="text/html; charset=utf-8" />
    after <head> tag.
    Goodluck.
    Khanh Le Moderator
    #243713
    The charset is set within the language you use. You could find and change the charset inside the language pack you are using.
This topic contains 3 replies, has 3 voices, and was last updated by  Khanh Le 16 years, 9 months ago.
