December 14, 2008 at 11:44 pm #136246
hi i am working localy on my computer and i use joomla 1.5
i installed the ja uvite template and everythibng was ok.
then i tried to modify parameters in the highslides module:
first of all i was not able to save anychanges because the save button disapered
second, from then on i was not able to go to the administrator pageis there anythinng you can do to help me??
sunrise Friendsunrise
- February 2007
- 166 times in 114 posts
December 15, 2008 at 5:00 am #282924I don’t know exact;ly which parameters you changed, but I think you should uninstall hisghslide adn the re install it and start again.
December 15, 2008 at 3:37 pm #282997I didn’t change any parameters. I tryed to change them but there was no save button!
- February 2007
December 16, 2008 at 12:20 pm #283089<em>@excel 95557 wrote:</em><blockquote>I didn’t change any parameters. I tryed to change them but there was no save button!</blockquote>
Can you unistall and then reinstall fresh?December 16, 2008 at 4:43 pm #283123i uninstalled and instelled frash but i still have the same problem
December 16, 2008 at 6:02 pm #283132however it works on my server.
do you know how it change the text “powered by highslide”??
SP Media FriendSP Media
- 70 times in 27 posts
December 23, 2008 at 12:32 pm #283857<em>@excel 95717 wrote:</em><blockquote>however it works on my server.
Thanks</blockquote>
Where does it say powered by high slide? That doesn’t appear on mine.
December 23, 2008 at 4:46 pm #283873i figured it out
it is a parameter in the pluginthanks anyways
rogydj Friendrogydj
- June 2008
- 2 times in 1 posts
January 27, 2009 at 12:37 am #288374attached you will find a picture with the explanation of the post..
1. i just click on the “new idea” .. i wanted to change the title, pictures, etc
2. the menu of admin panel disappear , the save and close button also gone
3. i try to access again the admin panel.. and here we are.. the print screen is what i got..ps: i fix that repairing the table in phpmyadmin (30 sec ago.. during i’m writing the post)…. it seems that it works now.. but i cannot guarantee..(first i reinstalled the joomla with the template..)
hope it works for you 2
Bye,
Rogy
melron Friendmelron
- February 2006
February 28, 2009 at 9:48 am #293903What did You do for the database? I have same problem, save and close button disappear when I open Highslide module. All other modules work well. Then suddenly whole database crash! This happend again if I re-install and try again! I have Joomla 1.5. and ja_zinc quicki nstallation package.
rogydj Friendrogydj
- June 2008
March 19, 2009 at 8:33 pm #296898ok
uninstall highslide and reinstall it
after this crash happens, go to yourdomain.com/phpmyadmin, select your database, check all the tables and with selected “Repair” .. as i said.. this works for me and i dont know if it is working for you!Bye
Rogy1 user says Thank You to rogydj for this useful post
hbf1000 Friendhbf1000
- June 2008
- 3 times in 1 posts
April 23, 2009 at 3:31 pm #302327Hi all, I have the same problem with this template. When I open the mod_jahighslide, my admin menus disapears. This is the second time I try to do this and it happened again.
- June 2008
April 23, 2009 at 3:58 pm #302329<em>@rogydj 118912 wrote:</em><blockquote>ok
Rogy</blockquote>Hi. Sorry, but I didn’t understand what you meant. I accessed my DB with PhpMyadmin but found no issue. Is there anything specific that I could look at ? Tks.
Just an update… I can see now a message saying “overcharge” in table jos_modules_menus … But have no idea what to do next….
AuthorPostsViewing 13 posts - 1 through 13 (of 13 total)This topic contains 13 replies, has 6 voices, and was last updated by hbf1000 15 years, 8 months ago.
Uvite highslides problem
