October 4, 2010 at 11:22 pm #154943
I have an unusual menu transparency problem with the main drop-down menu on my Uvite website. It seems to occur only with IE8 on Windows 7 and XP. I developed this website on my Vista laptop using Firefox and IE8, but never had a transparency problem with the main menu. The problem is that I can see right through the drop down menu, and the background shows, so the letter/words of the menu are hard to read.
After uploading/installing it up on Godaddy domain hosting, I started seeing the problem on other computers. See attached example or go to my website to see if you experience it or not: dev.glassandgardenchurch.org
How can I fix this? I cannot launch this new website until I fix this IE8 problem with Uvite main menu.
Saguaros ModeratorSaguaros
October 6, 2010 at 8:15 am #357904i checked your site on my pc and my friend ‘s pc, the menu worked well
October 18, 2010 at 5:42 am #359352I couldn’t get rid of the transparency problem, so I got rid of the transparency feature altogether. Too many browsers could not deal with it properly, so I made the drop-down menus in Uvite a solid brown, based on another tip I found in a forum.
October 20, 2010 at 2:46 am #359620Sorry, i dont have any tips for fixing this issue.
But you can, replace that transparent image background by background color :), its simple solution for your site to get it working on all browsers of your pc.
AuthorPostsViewing 4 posts - 1 through 4 (of 4 total)This topic contains 4 replies, has 2 voices, and was last updated by Saguaros 14 years, 2 months ago.
Uvite Menu Transparency Problem with IE8
