  • Kiên Trung Friend
    #188353
    I think ja fubix very hard to config module, position and layout of module, i already use joomla and template of joomlart i can control every thing but ja fubix i meet problem 🙁 don’t happy
    Sorry,
    Hi 1002,
    It’s sad to hear that, each JA template is different, due to the concept of every template, it will use different layout with various modules. Hence, new users may feel strange in controlling, but we’ve already provided details guidelines and documentation. If it’s hard for you to config / setup any extension or template, feel free to let us know and we are willing if you need any helps
    Kiên Trung Friend
    #496379
    Thank you, the my project very urgent but i post thread and waiting for reply it’s spend many time !
    Br,
    Would you like to post link of that thread here so that I can check for you?
    bule Friend
    #497364
    <em>@Saguaros 377408 wrote:</em><blockquote>each JA template is different, due to the concept of every template, it will use different layout with various modules</blockquote>
    here’s a couple thoughts about that
    whilst I appreciate that each template is different to some extent, after so many years of designing joomla templates surely it must be obvious to JA that there are a number of close similarities in positions that users expect to be used for similar modules.
    So at least some attempt at clarity and consistency in the naming of those would help to avoid confusion.
    for example:
    In hawkstore a ‘sidebar’ is called sidebar1 or sidebar2 – which is kinda descriptive == good
    whereas in fubix a module position which is in effect a sidebar is called position-5 or position-7 == wtf position is position-7?
    there are many others
    And ja templates often have positions defined that show up on module position selectors – but which dont exist in reality.
    So not including those would help to avoid confusion.
    for example in fubix: breadcrumbs
    regards
    b.
    Hi bule,
    You are right, our recent templates use sidebar1, sidebar2. Basically, the idea of using position-5 and position-7 is that default Joomla is using these positions and we keep it the same names.
This topic contains 6 replies, has 3 voices, and was last updated by  Saguaros 11 years, 5 months ago.
