  • Saguaros Moderator
    #1078683
    Hi @patin,
    There seems to be conflict with Hikashop Cart module, could you share the FTP account also?
    patin Friend
    #1078927
    http://ftp.ypress.eu
    users= support@ypress.eu
    pw=IdiotFiendPanderBulky65
    Site is places in subfolder /hika
    thank you!
    The problem seems to come from the template you’re using, it’s using JS to set the equal height for both main content part and the sidebar. However, the content in main part is longer than the height of sidebar so it caused above issue. I’ve added custom CSS to override this:
    .side-image.ml #midCol {
        height: auto !important;
    into the ‘custom.css’ file on your site, you can check it now.
    patin Friend
    #1079188
    Thank you, seems to have solved this issue! Great!
This topic contains 4 replies, has 2 voices, and was last updated by  patin 7 years, 1 month ago.
The topic ‘view problem’ is closed to new replies.
