February 22, 2016 at 12:47 am #887932
hello I’ve read the documentation 100 times I’ve tried all the solutions i found in forum but i still can’t get the vik working with your sample data. i keep getting this error:
An error has occurred. 1054 Unknown column ‘nominative’ in ‘field list’ SQL=SELECT
id
,custdata
,status
,idcar
,ritiro
,consegna
,idplace
,idreturnplace
,country
,nominative
FROMpier1_vikrentcar_orders
WHEREritiro
>1456178399 ORDER BYpier1_vikrentcar_orders
.ritiro
ASC LIMIT 6;Adam M ModeratorAdam M
- May 2014
- 1271 times in 1235 posts
February 22, 2016 at 10:09 am #888291I’ve installed the quick start package Vik com + mod , sql file with my database prefix. Vik shows on site but if I try to open Vik through administration I get this error.
- May 2014
February 23, 2016 at 8:11 am #888948Hi @nomrower,
Please have a look at this thread, try again and let me know the result then.
February 23, 2016 at 1:17 pm #889225Hello Adam
I’ve already read this post I’ve done this proccess for more that 10 times. (When I started over I deleted all files on server and the database also) Still not working.. Should I sent you my sql file? I Replaced wherever I found jarent with my tables prefixAdam M ModeratorAdam M
- May 2014
February 24, 2016 at 5:16 pm #889870Still the same luck. I did a fresh install again with the instructions you provided Adam but i keep getting the same error:
1054 Unknown column ‘nominative’ in ‘field list’ SQL=SELECTid
,custdata
,status
,idcar
,ritiro
,consegna
,idplace
,idreturnplace
,country
,nominative
WHEREritiro
>1456351199 ORDER BYpier1_vikrentcar_orders
.ritiro
ASC LIMIT 6;when i try to open VikRentCar from components in my Joomla Administration Panel. I also just noticed that when i try to change the theme colour for example it changes everywhere except HomePage. Why is this happening? Could it be the sql file you provided faulty? I would appreciate a fast response because I’ve been trying for 5 days now without success and the site has to go online asap. Thanks in advance Dimitrios
ps: im also attaching the sql file I’ve downloaded and edited (replaced jarent with my database prefix (pier1))
- May 2014
February 25, 2016 at 11:35 am #890236This reply has been marked as private.Adam M ModeratorAdam M
- May 2014
March 1, 2016 at 11:41 am #892886Adam I’m still waiting. nothing happened no-one checked the site. I’m stuck with this error and i can’t continue filling the site without the most important element working. It has been 10 days now and i have to wait 24hrs for each answer which also means nothing.
- May 2014
March 2, 2016 at 11:13 am #893407Hi @nomrower,
Sorry for the delay. I sent a request to ask about the issue status from development team but look like they’re still working on it. The problem is much complicated than expected so we would appreciate your understanding in this matter and we will reply back asap to let you know about the solution.
Best regards,
Adam.
- May 2014
March 3, 2016 at 8:57 pm #894454This reply has been marked as private.March 4, 2016 at 2:56 pm #894842Same result. nothing changed. still not working. I’ve reinstalled Vikrentcar successfully but I’m still getting the same error. Are we going to solve the problem? i don’t see any help coming. All the things you suggested doing I’ve already done. these are the first steps of troubleshooting. i need some serious help. i can’t wait any longer. I’ve been waiting for more than 12 days for a single problem which is not even my fault. the site has to go up…
This topic contains 22 replies, has 5 voices, and was last updated by Ninja Lead 8 years, 1 month ago.
