May 17, 2016 at 11:50 am #931575
After your last update for the template and vikrentcar my cars list shows up like the screenshot i have attached. Car details hide the picture of the car.
Luna Garden ModeratorLuna Garden
- July 2011
- 453 times in 425 posts
May 20, 2016 at 4:35 am #932531May 22, 2016 at 2:20 pm #933339This reply has been marked as private.May 23, 2016 at 2:17 pm #933778hello,
Im also facing another problem i just noticed. if you use the search engine on homepage in english language everything is fine but when i switch to another language (greek or italian in my case) after clicking on find cars on result page search cars sidebar is disappeared and if you continue to make a reservation and complete the steps there is no confirmation for the client no summary nothing just an empty page. i you use cars list though at any language everything is still working fine. why is that? why so many problems? do i have to wait for 10 days again for an answer? i need to get the site online as soon as possible.
thanks in advance
dimitrisLuna Garden ModeratorLuna Garden
- July 2011
May 24, 2016 at 10:40 am #934125Hi Dimitris,
It’s because in Module VikRentCar Search of other Language, you set Default Menu Item to ‘Choose cars’, this is Menu Item in English,you must choose to menu item of that Language.
For the error on Car list, we need more time to check this problem, if possible sent us FTP info of your site, it would help us find the solution soon.
- July 2011
May 25, 2016 at 4:33 am #934457Hi Dimitris,
For error ‘Car details hide the picture of the car.’, I can’t see folder com_virentcar in
templates/ja_rent/html/
Download and unzip the attachment to above path
May 25, 2016 at 12:13 pm #934619Hi Luna,
Ive downloaded your files followed your advice but now everything is misaligned and when i hit cars list prices are fine(without vat like i selected) but when i use the search engine prices show up with the vat included(i definitely don’t want that). I’ve contacted e4j team and they said that there is an issue with your overrides. I have also attached a screenshot so you can see what i mean.
I finally solved the first problem that was my mistake, sorry about that.
- July 2011
May 27, 2016 at 2:56 am #935209Hi,
You can send me the FTP account of your site so I can help to fix the issue.
Post the URL of page where I can see the problem, and add more details to the capture show what part you don’t want to display.
May 27, 2016 at 2:14 pm #935358This reply has been marked as private.Luna Garden ModeratorLuna Garden
- July 2011
May 30, 2016 at 5:51 am #935889May 31, 2016 at 3:40 pm #936489This reply has been marked as private.Luna Garden ModeratorLuna Garden
- July 2011
June 1, 2016 at 10:15 am #936712Hi,
I have uploaded folder com_vikrentcar to folder html of the template and it works well, you can check the link here: http://carrentalsmykonos.gr/index.php/en/component/vikrentcar/?option=com_vikrentcar&task=search&place=1&pickupdate=01%2F06%2F2016&pickuph=00&pickupm=00&releasedate=03%2F06%2F2016&releaseh=00&releasem=00&returnplace=1&categories=all&search=Find+Cars&Itemid=162
you will see that prices show up with vat included
So you want to remove part Price ?
June 2, 2016 at 9:14 am #937041If i choose cars list prices show up without vat (like i choose, like i want). If i use the search engine all prices show up with vat included. (i don’t want that, i want vat to show up on the last step of check out). From vikrentcar control panel I’ve already chosen show vat only on check out. Ive also contacted e4j and they said that its an issue with your template and your overrides.
- July 2011
June 3, 2016 at 8:31 am #937524June 4, 2016 at 11:34 am #937690Ok i did it total car cost is ok now but cost per day is still with vat included. I’m attaching a screenshot below. Cars list is still misaligned. I’m also attaching another screenshot. Look at the "Continue" buttons.
- AuthorPosts
This topic contains 15 replies, has 2 voices, and was last updated by Luna Garden 8 years, 5 months ago.
