  • lawman Friend
    #181416
    Aloha my name is Chris and I’m from Hawaii. I’m working with a church locally to create an amazing site. We have many features we would like to use and most them are working great. I really love joomla and want to continue learning. I’m new at this but have a few joomla sites under my belt and would like to continue learning more to grow my client base but could use help. I’m having problems, need help with VirtualMart issues, shopping cart database not loading and add to cart does not work. I’m guessing it is something simple but don’t know.
    I have update VM and joomla so I know they are all current. I only need to have the paypal shop part linked to VM. It seems easy and I think it can be done I just require help as it’s not working. I thought it would be easy as I just downloaded the template, modified all the graphics and added all my test products. I would like the checkout to give them the ability to use paypal. We have books and events I need to have as product do members can purchase them.
    HERE IS THE DEBUG TEXT:
    vmdebug self::$_jpConfig->lang en_gb
    vmdebug vmTime: loadConfig db no: 0.00518989562988
    vmdebug Start used Ram 16.25M
    vmdebug getUserFieldsFor cart BT -1
    vmdebug vmTime: VirtuemartControllerCart Finished task : 0.539514064789
    vmdebug End used Ram 30.5M
    vmdebug Peak memory peak 30.5M
    http://www.ltwhawaii.org/ is the website
    http://www.ltwhawaii.org/concept/ is the new joomla site.
    http://www.ltwhawaii.org/concept/index.php/inspiration-research-center is the store
    Sign up and I will give you the permission to make changes if you think you can help. Thank you in advance and have a great day.
    lawman Friend
    #470019
    ok got it working, it was a combo of settings for the shop config. Plus I needed to update the the new vm version 2b. Everything seems to work great now.;)
This topic contains 2 replies, has 1 voice, and was last updated by  lawman 12 years, 3 months ago.
