  • romolo Friend
    #208373
    We have uninstalled VirtueMart and re-installed it to get the the save, save & close, close, buttons working again.
    Since we have re-installed, we noticed we’re missing the “Grid” layout style in the VM Products module… Please see the following screenshots for example.
    Currently only have “Default” & “Single” layouts available: http://www.awesomescreenshot.com/ima…c0b1c6a7cd3db1
    This is the “Grid” option we are missing (on a separate website): http://www.awesomescreenshot.com/ima…b1502db4b4719c
    Please advise how to add this layout style into the custom module, in order for us to display the VM shop products in module position “home-1”.
    Ninja Lead Moderator
    #576697
    I could not see the screenshot of you mentioned above, you can give me it again, I will help you to check this bug.
    romolo Friend
    #576716
    Hi Ninja,
    http://www.awesomescreenshot.com/image/383175/618d70469c570ac7c4c0b1c6a7cd3db1
    http://www.awesomescreenshot.com/image/383169/5bc13d8665c8d0359ab1502db4b4719c
    #576783
    I don’t why on your site was missing modules/mod_virtuemart_product/tmpl/grid.php file, I uploaded it into your site and now you can see from the configuration on module
    #643096
    #741752
    romolo Friend
    #576806
    Hi @ninja Lead ,
    I guess it was missing the grid.php file, because we had to re-install VirtueMart.
    Many thanks for resolving.
    romolo Friend
    #643119
    Hi @ninja Lead ,
    romolo Friend
    #741775
    Hi @ninja Lead ,
    romolo Friend
    #664589
    Hi @ninja Lead,
    We’re having the same issue on a different site using JA Charity.
    We have had to re-install VirtueMart, but we don’t have this “Grid” feature.
    I will send you a private message with the login details. Please upload the grid.php file there.
    Or paste the file content on here and I will manually create.
    romolo Friend
    #746312
    Hi @ninja Lead,
    romolo Friend
    #664590
    Hi Ninja, nevermind, we have resolved this by manually uploading grid.php to the same destination on the other website…
    romolo Friend
    #746313
This topic contains 13 replies, has 2 voices, and was last updated by  romolo 9 years, 4 months ago.
