Viewing 7 posts - 16 through 22 (of 22 total)
  • Saguaros Moderator
    #1037723
    @framos41: I can access with different mode in Filezilla client and also solved the issue on your site. Here is my tweak:
    • In the file: root/templates/ja_megastore/html/com_virtuemart/productdetails/default.php
    • At approx line 256, where there is condition to show child categories and I replaced:
      if (VmConfig::get('showCategory', 1)) {
      echo $this->loadTemplate('showcategory');
    by this:
    if ($this->cat_productdetails)  {
    And it’s working now.
    framos41 Friend
    #1037838
    Thank you! everything solved now
    CDCG Friend
    #1041834
    We are experiencing the same error problem using the latest template version and VM 3.22
    CDCG Friend
    #1041835
    We are experiencing the same error problem using the latest template version and VM 3.2.2
    Did you try my above suggestion?
    doublemo Friend
    #1054037
    hello i have the same problem, i tried your suggestion but there is the same problem
    You can create a new topic and share the credentials of your site so I will take a look.
This topic contains 21 replies, has 6 voices, and was last updated by  Saguaros 7 years, 4 months ago.
