davidyv Friend
davidyv
- July 2007
- 2 times in 1 posts
December 16, 2010 at 4:03 am #157506I am using virtuemart 1.1.6 with latest JA T3 Framework for Joomla 1.5 quickstart(2010 version)
But when i click on product image in flypage, the image opened in current window (without lightbox) instead in lightbox in same window.
kindly help me to figureout it.
aman204 Friendaman204
- January 2010
- 418 times in 356 posts
December 16, 2010 at 6:41 am #367091Does it appear fine for you in default joomla template?
davidyv Frienddavidyv
- July 2007
December 17, 2010 at 2:39 am #367229Yes, it is fine in other default joomla template except JAT3.
- January 2010
December 17, 2010 at 6:49 am #367267<em>@davidyv 209108 wrote:</em><blockquote>Yes, it is fine in other default joomla template except JAT3.</blockquote>
Which template are you using ?
Also, Can you provide in direct site link to take closer look
- July 2007
December 23, 2010 at 10:35 am #368305I have kunena 1.6.1 and System – Mootools Upgrade enabled.
Everything works fine if change the template to rhuk_milkyway
- January 2010
December 23, 2010 at 11:34 am #368309Try to disable js compression in template parameters
- July 2007
December 24, 2010 at 12:39 am #368393I just disable js compression, but it still not work.
Saguaros ModeratorSaguaros
December 24, 2010 at 9:15 am #368458Hello David!
I have an answer on your ticket
K Schneider FriendK Schneider
- 11 times in 1 posts
April 5, 2011 at 9:50 pm #385029What is the answer?
I am using the template JA_BUSINESSdavidyv Frienddavidyv
- July 2007
April 6, 2011 at 2:44 am #385043<em>@ocean12 232473 wrote:</em><blockquote>What is the answer?
I am using the template JA_BUSINESS</blockquote>Hi ocean12,
The VirtueMart Developer Team has published VirtueMart 1.1.8, this version compatible with new Mootools 1.2.
April 6, 2011 at 5:31 am #385074But i am already using VM 1.1.8 and Joomla 1.5 and JAT3 2.0.
What step do I take to resolve this problem thenSaguaros ModeratorSaguaros
April 6, 2011 at 7:59 am #3851021) did you enable the mootools upgrade plugin?
as his issue, he enabled the plugin and i had a answer for him as following<blockquote>
Dear David!Thanks for contacting JOomlart!
I have checked your site
The problem is from the virtuemart component, it is not competitive with mootool 1.2.
When the rhuk_milkyway template is set as default, it work well because the template does not load the mootools of joomla.
</blockquote>K Schneider FriendK Schneider
April 11, 2011 at 9:32 am #385750Yes it is enebled
April 14, 2011 at 8:39 pm #386434No I have disabled it an its solved
This topic contains 14 replies, has 4 voices, and was last updated by K Schneider 13 years, 8 months ago.
