  • mmmkz86 Friend
    #814420
    Hello, <br/ >
    I am using uber (medicare) for my multilingual website. everything works fine with virtuemart in LTR but when in RTL virtuemart is kind of out of order and it looks like there is nothing like rows defined in it. to see whats really going on you can check virtuemart in RTL direction and compare it to virtuemart in English (use the links). you can also check the screenshots attached. I want virtuemart in RTL direction look like virtuemart in LTR. <br/ >
    <br/ >
    Thanks in advance for your help
    1. RTL
    2. LTR
    Pankaj Sharma Moderator
    #816096
    I do not have permission to check your site admin panel . Kindly upgrade the account to super user and update me so i can check the settings .
    mmmkz86 Friend
    #828817
    Hello Pankaj,
    I have sent you the superuser username and password and you have access to every back-end option as a super user. I have just hided the top menu in the back-end you have to use the left side panel to reach all the menus needed. let me know if there’s anything else you need, like Cpanel, to sort this out.
    Thanks for your help
    #829775
    this issue does not seems be from template as the VM css are giving 404 > http://prntscr.com/9hkrq5
    I also check the site with default Joomla template and same issue there , kindly contact to your host to check 404 issue in css , I also suggest to write the issue on Virtualmart forum .
This topic contains 3 replies, has 2 voices, and was last updated by  Pankaj Sharma 9 years ago.
