  • redserp Friend
    #142012
    I`m having a visual display problem.. Something is causing a transparency problem.
    Image with the problem is attached. Only hapens there!
    Any suggestion?
    Thank you
    1. problem
    scotty Friend
    #308360
    in template.css (line 583) you need to increase the min-height…
    #ja-containerwrap, #ja-containerwrap-c, #ja-containerwrap-cm, #ja-containerwrap-f, #ja-containerwrap-m {
    background: transparent url(../images/cw-bg.jpg) no-repeat scroll center bottom;
    clear: both;
    margin: 0;
    min-height: 510px;
    padding: 30px 0;
    redserp Friend
    #308366
    <em>@scotty 133277 wrote:</em><blockquote>in template.css (line 583) you need to increase the min-height…
    clear: both;
    margin: 0;
    min-height: 510px;
    padding: 30px 0;
    </blockquote>
    It didnt work. Problem unsolved even with 800px of min-height…. This is so strange!
    Thank you
    redserp Friend
    #308371
    Thank you scotty… i thought it wasnt that but after all it was 🙂
This topic contains 4 replies, has 2 voices, and was last updated by  redserp 15 years, 6 months ago.
