  • hayk Friend
    #150153
    i accentually published another module in the vm-cart position and now (after removing it and even uninstalling th other module) the vm cart module was missing the “see cart” button
    then i tried to move the vmcart to “left position” it was the same there
    then i unpublished it, and now it will not go away completely…
    i would like to get my vm-cart module position back
    and
    fix the cart module tas it was.
    i did all this after opening the site to the client!!:eek:
    thank you in advance!
    h.
    PS
    it seems like i got control over the vm cart module and were able to get the “add to cart” button back by making a copy of the vm cart module, the copy looks right-
    now just need to get back the vm-cart module position…
    it is coming up under template management preview section with all the other positions
    but not in the drop down list in the module manger anywhere
    Anonymous Moderator
    #339383
    Hi hayk
    It is so hard to debug your issues. If possible, please submit a ticket, send us your live url, admin account so that we have a closer look on your issue.
    Thanks alot
    hayk Friend
    #339387
    plz tell me where, i am out of time!!
    hayk Friend
    #339390
    can u at list help me decrease the gap between the header nav and the slider?
    thank you, i am very behind on this!
    1. Front-page-Instruction
    Dear hayk!
    Pls open the file: /templates/ja_zeolite_ii/css/template.css and find codes:
    #ja-header {
    line-height: normal;
    position: relative;
    z-index: 999;
    margin-bottom: 20px;
    pls adust the value of the margin-bottom property
    Good luck
This topic contains 5 replies, has 3 voices, and was last updated by  Saguaros 14 years, 8 months ago.
