  • amlinc Friend
    #148947
    Hi. I put the Shopping cart module in the vm-cart module position where you have it on the template example. First problem is the ‘Show Cart’ button is not there. It’s not there no matter what module position I move it to. So i can’t get to the cart unless i go straight to it when I add something.
    Also, i am using the cyan colored template and the writing in that module is cyan colored, since it’s up there on the logo part which is also cyan, i can’t see the writing. Where do I change this?
    thanks.
    bladerunner Friend
    #333699
    <em>@amlinc 166157 wrote:</em><blockquote>Hi. I put the Shopping cart module in the vm-cart module position where you have it on the template example. First problem is the ‘Show Cart’ button is not there. It’s not there no matter what module position I move it to. So i can’t get to the cart unless i go straight to it when I add something.
    thanks.</blockquote>
    possibly, i think the problem with cart button is related with “theme”(you can change it in VM configuration) when i have used a one which comes as default, i’v expierenced the same problem, than i’v tried manually to change it to the one from package for vm and it helped.
    amlinc Friend
    #333735
    There are no other options in the vm theme than default. do i need to add another theme? how do i do that?
    bladerunner Friend
    #333740
    there is them_ja_zeolite in package of Zeolite II – i uploaded it manually in to VM and it somehow helped
    to folder : directory listing for /public_html/components/com_virtuemart/themes/
    and after it in VM configuration/ site there is possibility to change
This topic contains 4 replies, has 2 voices, and was last updated by  bladerunner 14 years, 10 months ago.
