gringo211985 Friend
gringo211985
- May 2012
- 123 times in 27 posts
March 27, 2013 at 11:40 am #186245Hi there,
I have a strange problem with .modal popups with VM, see screenshot below
As you can see the product image is showing up near the search bar!
I read the other thread and tried the solution but it’s not working for me.
Please can someone tell me exactly what I need to change in the CSS files to correct this?
Thanks in advance 🙂
phong nam Friendphong nam
- May 2015
- 974 times in 888 posts
March 28, 2013 at 2:35 pm #488176Hi gringo211985,
I did get you PM for help. So, can you send me your ftp account via PM for fixing your issue ?
Regards,
Leogringo211985 Friendgringo211985
- May 2012
March 29, 2013 at 10:15 am #488273<em>@Leo Burnetts 366656 wrote:</em><blockquote>Hi gringo211985,
Regards,
Leo</blockquote>Thanks LEO I will send you those details over for you.
- May 2015
March 29, 2013 at 5:17 pm #488317Hi gringo211985,
I did fix this on your site. Your shop1 menu is using VM Frontpage menu item. So, do this :
Open /components/com_virtuemart/views/virtuemart/tmpl/default_products.php . Then at line 58 replace<blockquote>echo JHTML::_ ( ‘link’, JRoute::_ ( ‘index.php?option=com_virtuemart&view=productdetails&virtuemart_product_id=’ . $product->virtuemart_product_id . ‘&virtuemart_category_id=’ . $product->virtuemart_category_id ), $product->images[0]->displayMediaThumb( ‘class=”featuredProductImage” border=”0″‘,true,’class=”modal”‘ ) );</blockquote>
with
<blockquote>echo JHTML::_ ( ‘link’, JRoute::_ ( ‘index.php?option=com_virtuemart&view=productdetails&virtuemart_product_id=’ . $product->virtuemart_product_id . ‘&virtuemart_category_id=’ . $product->virtuemart_category_id ), $product->images[0]->displayMediaThumb( ‘class=”featuredProductImage” border=”0″‘,false,’class=”modal”‘ ) );</blockquote>
Regards,
- May 2012
April 1, 2013 at 9:49 am #488445Thanks Leo,
This fixed worked perfectly, will mark as solved.
AuthorPostsViewing 5 posts - 1 through 5 (of 5 total)This topic contains 5 replies, has 2 voices, and was last updated by gringo211985 11 years, 9 months ago.
VM Modal popup problem
