Hello all,
After a verry fresh install with the Quickstart (1.5.5) the first thing I did was upgrading VM 1.1.1. to 1.1.2 via the check for updates in the VM admin
:confused: Since then it is not possible to put a product into the cart.
I get a popup which say:
Info: To add this product into your cart you have to select a product variant on the details page. As you know there is no product variant in the standard products.
Anyone the same problem and a solution?
Extra info:
After upgrading to VM1.1.2.:
Featured products from the homepage can be added to the cart directly via the add to cart button
Adding “Normal” products from the shoppage give the error mentioned above ???
Thanx, John
